F55: modified slog2 to REC709 LUT downloads at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
35mm CMOS Sensor / 4K Ultra-HD Camcorders
Old March 8th, 2013, 06:39 PM   #1
It's been a few crazy days after getting the F55 and shooting without an exposure tool and working with LUT's in post... but results so far have been great in my opinion.
Below are some samples of modified LUT's I created based on Sony's slog2 LUT and I've also included links to download the LUT's incase you want to play around and try them yourself.
You may need to reduce your scene contrast first before applying the LUT. Further descriptions are in the ZIP file.
These are based on the sony slog2 -> REC709 lut meant for slog2 with s-gamut color space.
slog2sg_to_rec709_STARCentral.001 - LOW CON 01 LUT rar | zip
slog2sg_to_rec709_STARCentral.002 - GOLDEN TEXAS LUT rar | zip
ORIGINAL SLOG2:
LOW CON 01 LUT:
GOLDEN TEXAS LUT:
Dennis Hingsberg is offline   Reply With Quote
Old March 8th, 2013, 06:55 PM   #2
Re: F55: modified slog2 to REC709 LUT downloads
Here is the video from frames seen above. The short clip has a 200% post blow-up, as well as a post digital zoom and pan.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems > Sony XAVC PMW-F5 / F55 CineAlta
