BD-R and 25P at DVinfo.net
Old November 11th, 2007, 12:50 PM   #1
BD-R and 25P
I do not know whether this has been already discussed somewhere else but I believe this concerns the EX1 as well.
I've just learned that both BD-R and HD DVD do not support 25P. Basically it seems that PAL is a problem when it comes to output to either format. So for all PAL users intending to buy this camera, what will you be using to be able to give a disc to a client having high definition footage on it? I was thinking of using 1080P at 25 fps - but will I be able to output to a BD-R with maximum compatibility with current existing BD players?
Brian Cassar is offline   Reply With Quote
Old November 11th, 2007, 01:20 PM   #2
You can export 25P within a 50i stream and the end result won't be any less progressive looking.
It'll work fine.
Barlow Elton is offline   Reply With Quote
Old November 11th, 2007, 02:04 PM   #3
This problem has been discussed extensively in the V1 forum. Editing 25p is as easy as a breeze, but displaying it properly is another matter. When you send the 25PsF (25p within 1080/50i) over component (or HDMI of most HDTVs), the display will try to deinterlace it which results in a horrible line twitter. There are 2 ways of displaying 25PsF properly:
- from the PC, using a software MPEG player with deinterlacer OFF
- on some newest, top line HDTVs, usually one of their HDMI inputs can tell it's progressive and won't deinterlace (not possible over component, though).
Add to it the fact that 25p is not supported by BluRay or HD DVD, and you have the answer: 24p is the way to go, even for the PAL users.
Unless (and I kindly ask those knowing it for sure to enlighten and/or correct me), the EX1's 25p is NOT 25PsF, but native progressive just like 24p at 35Mbps VBR, in which case it should be correctly recognized as such by most viewing devices. But I'm just speculating here!
Old November 11th, 2007, 02:10 PM   #4
I'm under the impression that 24P is not available for PAL in the EX1 - or am I wrong?
Old November 11th, 2007, 02:12 PM   #5
You're not wrong, but what can stop you from setting it to NTSC ?
Old November 11th, 2007, 05:37 PM   #6
Hadn't really thought about that, Piotr. I have an inexpensive Vizio 1080p set that does a good job of leaving progressive alone, as I have viewed 30p played from a 1080i output and had no annoying interlace twitter issues.
