Cost of the SXS card reader.... at DVinfo.net
Old November 13th, 2007, 09:59 AM   #1
Well, I might as well ask it now....
Why does the SXS card reader cost so much........
Old November 13th, 2007, 10:04 AM   #2
Four letters...
$ O N Y
;0)
Truth is, no-one else makes them (at the moment) so early adopters will be footing a large part of the R&D costs until demand and production meet each other on more equal terms.
Play to Learn,
Learn to Earn,
Earn to Play...
Dave - Broader Pictures
Dave Elston is offline   Reply With Quote
Old November 13th, 2007, 03:09 PM   #3
On the other hand try to get a minidv or hdv deck for less.
Chris Forbes is offline   Reply With Quote
Old November 13th, 2007, 04:34 PM   #4
Of course, depening on your workflow you can always use the USB port on the camera. It's not like you're wearing out heads.
Old November 13th, 2007, 05:00 PM   #5
Originally Posted by Dave Elston View Post
no-one else makes them (at the moment) so early adopters will be footing a large part of the R&D costs....
Doesn't SxS fit in a standard ExpressCard slot? If the reader costs more than a couple hundred dollars, why not just buy a cheap laptop with one of those slots in it?
Old November 13th, 2007, 05:33 PM   #6
The SXS card will plug directly into a MacBookPro or Sony Vaio (not sure which models). I don't think those are cheap laptops though.
MacBook, for example, does NOT have ExpressCard slot.
I think the card readers will be the convenience of loading into a desktop NLE without the camera. Unless one has more cards than needed on a shoot, I can't see too many situations where you're sending the camera out on shoot while someone offloads other cards at "the office." That day may come though.
Old November 13th, 2007, 07:03 PM   #7
On set it is nice to have the choice of express card or USB 2.0 some DIT's are using the express card slot on their mac for Sata cards.
Old November 14th, 2007, 03:59 AM   #8
my Dell M90 has an express slot seemingly which I now know of now that I need one...lol
So looks like I am set so.
Alan Waters is offline   Reply With Quote
Old November 14th, 2007, 06:21 AM   #9
The Macbook Pro has a 34 card slot dosen't it need a 54 card slot?
Paul Cronin
www.paulcroninstudios.com
Old November 14th, 2007, 06:27 AM   #10
Images: 3
34 card slot
Old November 14th, 2007, 06:27 AM   #11
SxS cards are 34.
Old November 14th, 2007, 06:54 AM   #12
Thanks Craig
Paul Cronin
Old November 14th, 2007, 07:25 AM   #13
Just google-bumped into this...
http://onlinestore.siig.com/shopexd.asp?id=863
Only question is whether SxS cards are "USB-based" or "PCI-e based" cards(?) If the former, then at $40 this represents a genuine saving of $200+ over the Sony reader!
EDIT: I suspect the latter is true judging from some specs for the reader that I've checked over at http://www.creativevideo.co.uk/publi...productID=4287
At least that would explain the price delta.
Play to Learn,
Learn to Earn,
Earn to Play...
Old November 14th, 2007, 08:14 AM   #14
So does that mean the "USB based" versions are not compatible, or is the transfer rate slower?
Old November 14th, 2007, 09:10 AM   #15
extract from the "More Details" link for the cheaper reader:
http://www.siig.com/ViewProduct.aspx?pn=JU-000012-S1
"Important: This adapter only works with USB-based ExpressCard devices. PCI Express-based ExpressCard devices will not be detected. Please check with your device’s manufacturer if you are not certain"
My guess is that it's a bus/pin compatibility problem which Sony have overcome with their pricier device.
Play to Learn,
Learn to Earn,
Earn to Play...
