problem when down convert - Page 2 at DVinfo.net
Old January 27th, 2008, 10:05 PM   #16
Originally Posted by Joel Klein View Post
if my source is 30P dose it make any differenc?
Hi Joel,
If you're outputting it as progressive frames, then no, this setting won't be used (e.g., going from 1080p30 to HD 1080p30). But, if you're downconverting to interlaced, then you need to specify the frame order for it to play back correctly.
Brent
Brent Ethington is offline   Reply With Quote
Old January 28th, 2008, 04:27 PM   #17
every SD dvd must be interlaced?? in order to play back better?
Go for 16 gig Ram its worth!
Joel Klein is offline   Reply With Quote
Old January 28th, 2008, 05:40 PM   #18
Phleeeease, could someone (with sufficient knowledge) post a workflow (in steps) of down converting form HD to SD and then sending to SD DVD. The more I read about it the more confusing it gets!
I think this is one of the greatest concerns living in a transitional face. A lot of us will be shooting HD and down converting to SD and then to SC DVD. Any input would be greatly appreciated.
Pavlos Symeon is offline   Reply With Quote
Old January 28th, 2008, 05:53 PM   #19
yes! please read this
http://www.dvinfo.net/conf/showthrea...d=1#post816158
Old January 28th, 2008, 05:58 PM   #20
Thanks Joel!
Old January 29th, 2008, 10:15 AM   #21
Joel,
Yes - that's my understanding. For the best compatibility, interlaced is best - many players will then deinterlace to 480p on playback.
Brent
