Portable hard drives? at DVinfo.net
Old February 14th, 2008, 08:02 PM   #1
While reading some PR material from Sony on the EX1, I came upon this quote:
"The SxS PRO cards are designed to speed up post-production by improving workflow and import times. Portable hard drives can also be attached to the camcorder."
(here's the link: http://www.sony.co.uk/biz/view/ShowC...veContext=true)
Has anyone attached a portable drive to the EX1?
Alex
Alex Kanakis is offline   Reply With Quote
Old February 15th, 2008, 03:00 AM   #2
There are several threads already about this. Basically you can attach any external recorder for the supported interfaces/output modes.
Some recent developments are the Convergent Design Flash XDR which can capture the HD-SDI 10bit 4:2:2 output to (cheaper) flash cards, and the CineForm HDMI recorder mentioned here.
Firestores and the like are reported to work as well, but are limited to the HDV modes.
George/
George Kroonder is offline   Reply With Quote
Old February 15th, 2008, 10:16 AM   #3
I wonder if it is possible to capture the 25mbps stream to a device like a Firestore, while simultaneously recording to SxS cards at 35mbps (I seriously doubt it).
Robert M Wright is offline   Reply With Quote
Old February 15th, 2008, 10:18 AM   #4
No it is not - once set to any HQ mode, the EX1 simply disables i.LINK.
In spite of this limitation, I decided to keep my DR60 drive. The 25Mbps is still of great quality thanks to the imagers and lens of this camera, so should need arise for a long recording I can always use it (I have tested both 1080/50i and 24PsF with pull-down, and both look better than those from the V1). Also, I'm going to always take it with me each time I carry my laptop for in-field HQ stuff off-loading; the material will go the Vaio's internal drive AND the DR60 as a temporary backup (in data mode, of course - it'll spare me buying a separate portable drive).
Old February 15th, 2008, 10:30 AM   #5
It's a real shame that the firewire is disabled in HQ mode. Firewire is certainly capable of transmitting data at 35mbps.
Old February 15th, 2008, 12:53 PM   #6
Or porting eSATA out directly from the camera.
Steve Kahn is offline   Reply With Quote
Old February 16th, 2008, 09:08 AM   #7
will the Sony EX-1 work with the Cineform Portable Recorder?
Nicky Campos is offline   Reply
