IKAN HD8000 $795 (as advertised here) - Page 2 at DVinfo.net
Old February 26th, 2008, 09:59 AM   #16
The EX1 doesn't have a menu option where you choose what it's component puts out? I've got to test this next time I use one.
Evan C. King is offline   Reply With Quote
Old February 26th, 2008, 10:43 AM   #17
Images: 12
Originally Posted by Michael H. Stevens View Post
Me too Randy. The problem is the good ones are expensive. DVmag did a review last month. I will try to find it. It is no point getting one unless it is at least 8", full HD horizontally and capable of playing progressive HD.
I am OK with a setup under 2K. Let me know if you find the info. Is there a brand that specializes in this niche that I could look into? The stock LCD is terrific for initial focus (with the magnification option) but there are times that I simply can not see that I've lost focus to DOF as the subject approaches the camera (surfing, etc). It will also be useful to have a more readable histogram.
Randy Strome is offline   Reply With Quote
Old February 28th, 2008, 05:23 PM   #18
Images: 12
This one was suggested to me for the EX1. Pretty interesting.
http://www.tvlogic.co.kr/eng/product...d/lvm_spec.pdf
Old February 28th, 2008, 06:14 PM   #19
The SONY monitor made for the EX1 is the LMD-9050. It is HD via HDSDI which is what you want and there is a $250 rebate for EX1 owners. Price is $4125.
Based on specifications, this monitor doesn't support 1080p, either (apart from 24PsF, which is embedded in 60i). No native 24 or 25p, though.
Old February 28th, 2008, 09:57 PM   #20
Images: 12
A couple more that appear to. I like the waveform and vs on the first though.
http://www.lcdracks.com/monitors/vr70phdsdi.html
http://www.lcdracks.com/monitors/v-lcd84sb-afhd.html
Old February 28th, 2008, 11:40 PM   #21
Originally Posted by Tim Polster View Post
Paul, how do you get better slo-mo in 1080i compared to 720p60?
The 60p stuff I have seen is without equal.
I'm not Paul, but I'm sure he uses the old trick of *interpreting fields as frames*.
This doubles the length of the footage (at the expense of the resolution), and allows for a very quick and good looking (artifact-free) half-speed slo-mo.
Alex Raskin is offline   Reply With Quote
Old February 29th, 2008, 08:41 AM   #22
Thanks.
I still don't see how 60 fields is better than 60 frames.
And on the topic of monitors.
I don't understand why all of these LCD monitors are so expensive when their resoultion seems low to me.
Computer LCD monitors (while I know are mass produced and are not as special as broadcast monitors) have been high resolution and costing in the low hundreds for a long time.
I would rate focus and exposure as being the most important elements for a preview monitor. And this seems pretty obtainable with a computer LCD, it's just that they are all A/C and often too large for location work.
Tim Polster is offline   Reply
