Nikon to EX3 adapter made by MTF at DVinfo.net
Old October 15th, 2008, 07:14 AM   #1
Just got my new Nikon to EX3 adapter made by Mike Tapa. Excellent craftsmanship and works great! I have used it with a range on Nikon lenses up to 600mm 5.6 and it delivers the goods ! Its great for wildlife as due to the small sensor relative to the 35mm sensor – you get a x5.5 crop factor !
It is basically a ring – no optics or automatic control but I use it with manual focus lenses. Histogram, peaking, zebra, works fine.
Here is a photo of the EX3 with a Nikon 600mmf5.6 mounted via the MTF adapter examined by my 15 months old assistant Jonathan Levy.
Ofer Levy Nature Photographer - New Photos
Cheers,
Ofer Levy is offline   Reply With Quote
Old October 15th, 2008, 07:19 AM   #2
no rails?
Definitely don't wan't to add an Anton-Bauer or IDX battery on the back of that!
Sony EX3, Vegas 9.0 64bit, Windows 7(64), Core i7, 12GB, RAID1 & 0, HotSwap SATA, 30" LCD(2560x1600)-GTX285 & 24" LCD(1360x768)-7800GT
Ted OMalley is offline   Reply With Quote
Old October 15th, 2008, 07:53 AM   #3
Don't doubt that it's Jonathan Levy, but surely it's the 500mm f4P, not the 600?
Excuse me for being such a Nikon geek!
Steve
Old October 15th, 2008, 09:07 AM   #4
Great shots!
But, oy, I would really be concerned about hanging an EX-3 off that lens without either rails or tripod support.
Ned Soltz is offline   Reply With Quote
Old October 15th, 2008, 09:28 AM   #5
I wouldn't be too concerned
Sony EX1 v1.11, crap loads of SxS, Macs w/ Final Cut Studio
Last edited by Andrew Hollister; October 15th, 2008 at 08:31 PM. Reason: removal of offensive bits
Andrew Hollister is offline   Reply With Quote
Old October 15th, 2008, 06:00 PM   #6
Originally Posted by Andrew Hollister View Post
I wouldn't be too concerned, with that angle, it looks as though it will just swing down and hit the boy in the head... young Jonathan will prevent any real damage ;)
Your sense of humor is not appreciated!
Old October 16th, 2008, 02:26 AM   #7
Ofer, another option instead of having a support plate, if you get a second pan handle, you should be able to turn it so that it rests under the camera base and gives it some support.
Steve
Old October 16th, 2008, 02:33 AM   #8
Steve
Oh yes, Ofer - by all means, give some more support to your precious rig!
Old October 16th, 2008, 02:59 AM   #9
Hi Ofer,
Here's a link for a home made support
http://www.dvinfo.net/conf/under-wat...-sony-ex3.html
several threads down
Regards
Mick
Mick Jenner is offline   Reply With Quote
Old October 16th, 2008, 04:29 AM   #10
Thanks guys !! I will definitely get some more support!!
Old October 16th, 2008, 04:34 AM   #11
Don't do it just because we say so, your judgment is best, maybe we're all wrong and you can by without it. I know your position, being a wildlife photographer you want to keep everything as simple, and most importantly light as possible, so anything you can do without then great. I would worry about the integrity of cam and lens mounts, but also you'll probably get more shake if the two units are not both supported.
Very best wishes,
Steve
Old October 16th, 2008, 05:46 AM   #12
Where did you get that ...
Cheers,
What the link or name of the adapter? Not to worry ... found it. Does anyone have an example of the 5.5X magnification factor the Tapa adapter gives?
Last edited by Dean Harrington; October 16th, 2008 at 05:54 AM. Reason: found a link
Dean Harrington is offline   Reply With Quote
Old October 16th, 2008, 05:47 AM   #13
It's MTF Services Ltd Ex Optex engineer Mike Tapa. He's just re-jigged his website.
Steve
Old October 16th, 2008, 11:22 AM   #14
I just noticed that the company making the adapter also makes a support. Here is a link.
Lens and matte box support
I know nothing about it, but, I thought some of you might be interested in knowing it exists.
Eli Schmukler is offline   Reply With Quote
Old October 16th, 2008, 12:00 PM   #15
That is exactly the kind of support I had in mind when I saw Ofer's set up.
