BNC spiggot rubber cap on EX-1 keeps falling off at DVinfo.net
Old April 13th, 2009, 02:11 PM   #1
Hi,
How's everything going today? Good I hope.
Does anyone have thoughts about how to keep the rubber cap from falling off on the HD/SD-SDI BNC connector? I can imagine a project involving glue and tether. Anyone have experience with this type of do it yourself operation? Just trying to learn from someone who has done it already, preferably a more elegant way than glue. Or does somebody sell a better cap that will stay on. I hear another inflated price product idea coming on guys. :0
Thanks in advance
Max Allen is offline   Reply With Quote
Old April 13th, 2009, 02:24 PM   #2
When did you get your EX1?
The original cap on the older EX1 had this issue but Sony replaced with a better fitting cap. I'm under the impression if you contact Sony you can get the newer better cap.
Old April 13th, 2009, 03:45 PM   #3
I got my EX1 early last year. I believe that at one point after removing the EX1 from the carton there indeed was a cap. Poof! Gone since. I haven't worried about it since either. I suppose if I worked in harsh conditions I might get a new cap. I thought of fashioning one from a BNC plug, I have plenty. It would be locked on then but that little task got merged with all the other things that have lower priority.
Keith Moreau is offline   Reply With Quote
Old April 13th, 2009, 03:54 PM   #4
the best would be to find either a bnd/cinch adapter where ou close the hole on the cinch side or better (because shorter) a BNC 50 Ohms terminator where you removed the 50 Ohms resistor. Both are metallic and are attached like a BNC, so no risk to loose them
bnc terminator 75 ohm - Google Image Search
bnc cinch adapter - Google Image Search
Old April 13th, 2009, 03:57 PM   #5
Get a new replacement from Sony.
Regarding the BNC plug, anything that protrudes even a small amount is just that might of a risk it gets knocked into and bent.
Old April 13th, 2009, 03:57 PM   #6
u can get little covers / caps for them like this
http://marchantelectronics.com/index.html/ep314.jpg
Matt San is offline   Reply With Quote
Old April 13th, 2009, 10:44 PM   #7
Those look interesting.
Do they come in black?
Reel Inspirations - www.reelinspirations.com
Commercials, Dramas, Image Pieces, Documentaries, Motion Graphics
James Huenergardt is offline   Reply
