Help with Clip Browser 2.5 at DVinfo.net
Old April 18th, 2009, 09:17 AM   #1
Hello,
I have recently aquired an EX-1 and am using the Clip Browser to transfer my files.
I was wondering if somebody could help me with some settings or ways to transfer the files.
1). I often don't need metadata. Is there a way to end up with just the video footage on my hard drives? When I transfer a long shoot there a lot of folders and I have to dig around just find the video to input into my NLE. Seems overly complicated.
2). I use Edius. Is there a reason to use mpeg-4 or MXF?
3). If MXF, how to I make this conversion? I have some MXF setting set, but the file does not seem to be MXF on my hard drive.
Thanks for your help!
Old April 18th, 2009, 09:39 AM   #2
In ClipBrowser
File/Export/MXF for NLEs
If Edius can use the MP4 you don't need to do the above.
Back up the ENTIRE BPAV folders though. Other NLEs may need them. You do NOT want to destroy the integrity of the camera masters.
Old April 18th, 2009, 10:29 AM   #3
I see now. Thanks.
So I need to/should have the folders involved?
I guess Edius does not need them but other NLE's do?
Old April 18th, 2009, 10:50 AM   #4
Originally Posted by Craig Seeman View Post
In ClipBrowser
I use Newtek SpeedEDIT, which can work with .mp4 file created in EX-1. So, as Craig mentioned, back up Entire BPAV folders placing them into a parent folder with a meaningful name. Then, to simplify bringing them into your NLE, make a search within the parent folder for .mp4 files. Then copy only .mp4 files to another folder with a meaningful name onto a different drive - it will be, sort of, another backup. After that import .mp4 files into your NLE.
Just my 2 cents...
Thank you.
Ilya Spektor is offline   Reply
