EX3 Recording Solutions
At 50 mbs or 100 mbs (1080) which tapeless recording solution on the market will hold the most media. With a typical shoot of ours we will shoot between 360 to 520 minutes in remote areas. Is there anything that can hold that much media that can be attached to your EX3 camera, Nano Flash, Firestore, ETC.... Definitly dont want to buy 6 to 10 SXS cards X 8 Field Producers =48 to 80 SXS cards, Ouch. THanks
Vortex Media
Pxu-ms240
John,
This unit has not been released yet, but I think it will solve your problem. PXU-MS240 Mobile Storage Unit From Sony Give a PXU-MS240 and two SxS cards (even 8GB) to each of your field prducers, and they could shoot for days. 240GB capacity. 10X transfer speed. No computer needed. Built-in error checking. Battery operated. And more reliable than SD cards. How much? I think it will cost less than $1500 including one 240GB cartridge. Additional cartridges might cost around 400 bucks. Not as cheap as other hard drives, but they aren't ordinary hard drives. Would you pay $1500 for the equivalent of a 240GB SxS card? I would.
Vortex Media http://www.vortexmedia.com/ Sony FS7, F55, and XDCAM training videos, field guides, and other production tools |
The OP was looking for 50 or 100Mb/s recording. I would go with the NanoFlash and a Nexto ND2725.
If you get 4x 32Gb cards for the NanoFlash at 50Mb/s that gives around 4 hours of record time. Then offload to a 500Gb Nexto which will hold 15 hours of material for $500 ish.
Alister Chapman, Film-Maker/Stormchaser http://www.xdcam-user.com/alisters-blog/ My XDCAM site and blog. http://www.hurricane-rig.com |
Great, the link to Nexto is Nexto DI - Next Generation Storage with Digital Interface thanks for the help..
#5 |
Vortex Media
Thanks Alister. I need to get glasses! :-)
NanoFlash is definately the way to go.
#6 |
Ohhhh don't talk to me about glasses. I had to get reading glasses for the first time this week.
Have you tried the NanoFlash yet Doug? It's sweet.
#7 |
Vortex Media
Nope, I haven't tried it yet but Dennis Dillon raves about it. If you and Dennis say it's good, that's good enough for me. I just don't have a need for buying one it at this time.
The HQ mode of the EX3 is plenty good enough for me right now, so why bother with the extra gear? I do have to record HD-SDI and HDMI output from other cameras quite often so I have an EX30 deck mounted in a Pelican case and running off NP1 batteries. (Note: HDMI recording requires an AJA converter). I thought about using the Nano, but the EX30 is so much more versatile and I like keeping all the footage with the same codec and on SxS cards. I can also use the EX30 for playback screening when I get back from a shoot, importing, etc. It's a nice unit and fits my needs better than the Nano. But I'm keeping an open mind because everything I've heard about it is positive. PS. I starrted using reading glasses last spring. Not even close to needing prescription glasses, though! Knock on wood.
Vortex Media http://www.vortexmedia.com/ Sony FS7, F55, and XDCAM training videos, field guides, and other production tools Last edited by Doug Jensen; September 16th, 2009 at 05:59 PM. |
#8 |
Doug,
The step up to 50Mb/100Mb in the Ex line is a big bumped up in quality, but one has to scan the files at 20x20/ or less, pixel sample to see what is really going on. A simple test of random viewers may not see a difference in 90+% of the original EX footage. The real test is in high demand situations for the EX @ 35 Mb. You know the ones. This all comes down to how much compression in a given situation satisfies your needs. A Cost base/Data space analysis, will determine if a Nano, or for that matter any flash system, is right for yourself or your clients. Let the truth be told, my network clients have no F---kn idea what Im talking about, but they do like a pretty picture that drags and drops into their timelines without a hitch. I have suggested a possible EX/XDCAM workflow to Dan @ CD and Chris @ Sony and we may soon have a great solution to write EX/Nano files 422 50Mb to optical clip folder/Proxies !!!!!. Stay tuned. |
#9 |
The quality of 35Mb EX footage still amazes me even after 2 years of use. However the nano allows me to do much more with my material in post production and I don't worry so much about multiple generations. I understand your desire to keep everything in one format. I'm looking at making 100Mb/s NanoFlash files my "standard" format. I love being able to take my pocket sized Nano to events to play back footage at 100Mb/s.
#10 |
Hello Alister,
I am curious, on the subject of quality if you take 35Mb EX footage put it onto the time line and export to DVD. Then repeat the same process with the Nano files 100Mb/s. Assuming that the same software and settings was used in both cases would you be able to pick the difference. Thanks |
#11 |
It depends on whether you grade or treat the footage. If you do any moderate to heavy grading them I would expect the NanoFlash files to have an edge. If you do nothing to the material then I would not expect to see a difference.
#12 | |
Vortex Media
I've got some green screen work coming up later this year, and the Nano might be just the ticket for that.
#13 |
Doug the Nano is worth every penny. If you would like to set up a time we can meet so you can try my Nano.
#14 |
Vortex Media
Paul, that'd be great. Thanks for the offer. Maybe we can meet at Beavertail in October because I'm out of town this week and I'm booked every day through the end of the month. I might have something else for us to test at the same time if we wait.
#15 |
Sounds good Doug,
I am flat out till the end of the first week of Oct and then on the road most of Nov. So Oct sounds great and Beavertail is a nice place in the afternoon golden light. I have Sandisk Extreme III and IV cards so we can shoot slow motion in I-Frame and 100 bit rate long GOP. Just send me an email when you know what works for you. |
