EX3 shoulder-upgrade by dm-accessories at DVinfo.net
Old November 17th, 2009, 10:01 AM   #1
Hi:
On my EX3 I already have this dm-reinforcement plate:
DM-Accessories - EX3-PLATE Reinforcement Plate for EX3 Camcorders
Now I am thinking of putting on this dm-shoulder-upgrade:
DM-Accessories - EX3-PLATE to EX3-SHOULDER upgrade
Does anybody already have it and is it a good buy? Does ist really help to give the EX3 a better shoulder-rest?
Thanx!
Heiner Boeck is offline   Reply With Quote
Old November 17th, 2009, 11:48 AM   #2
I have it and I love it especially as I use a Tiffin steadystick in the front. Steady Stick at DVcreators.net
Leaves me with two hands to operate the camera and I have little to no fatigue. With just the dm shoulder support you still have to support a lot of front weight.
David Herman is offline   Reply With Quote
Old November 17th, 2009, 03:52 PM   #3
I use the DM shoulder mount but with the Eng Rig Pro from dvtec.
While a more expensive solution than the Tiffin, I think it is a far more robust solution complete with Sony wedge plate and adjustable rails.
Ned Soltz
Ned Soltz is offline   Reply With Quote
Old November 18th, 2009, 02:22 AM   #4
Ned, how useful/usable is the shock absorber in the rig's pole?
Old November 18th, 2009, 03:04 AM   #5
The newer version of the DM baseplate and shoulder mount is excellent, far better than the original version which was a two piece baseplate.
I have used this for the past six months and it provides exceptional stability to the camera.
Old November 18th, 2009, 09:54 AM   #6
The shock absorber in the pole is very effective. Mind you, it is not a Steadicam. It does provide a certain amount of shock absorbtion but most importantly it allows the camera to be positioned and then locked down.
Old November 18th, 2009, 11:51 AM   #7
Sorry, Ned, but I see no Eng Rig Pro on the dvtec site. I see an EngRig (not Pro) and I see a DvRigPro. So, which one is it that you recommend? Because I sure need a decent rig for my EX3 (for which I have also ordered the Redrock 35 mm adapter).
Adam Stanislav is offline   Reply With Quote
Old November 18th, 2009, 01:29 PM   #8
I have the Ex3 Camera and the BEBOB COCO-EX3-V attached to the bottom of it for my VLock batteries and sennheiser radio mic.
I also have the TLS VCT14-Adapter that allows use of Sony VCT-14 quick release tripod plate.
Everything work OK but I would like the camera to be shoulder mounted.
I was thinking of getting this shoulder mount.
and attach it to the bottom of the EX3 with the Bebob attach too. Jeff told me it would, he supplies longer screws.
Just wondering, would I also need the pivoting back plate and could I ask, hows the padding on these mounts sticking it, has any come loose with ware.
Going from the picture, I don't see any protective material wrapped around it.
Thanks in advance.
Anthony McErlean is offline   Reply With Quote
Old November 18th, 2009, 03:35 PM   #9
I must have just added the Pro by accident-- it is ENG Rig
Ned
Old November 18th, 2009, 03:59 PM   #10
OK, thanks, Ned.
