Ext audio missing on EX1 manual setting? at DVinfo.net
Old February 18th, 2010, 03:40 PM   #1
I cannot figure out why external 48v mic works in auto mode but when switched to manual there is no sound! Have checked EX1 audio volume is set to -35db trim and pot is at 5 as usual, it was all working normally till now. Has anyone any ideas?
Bruce Rawlings is offline   Reply With Quote
Old February 18th, 2010, 04:36 PM   #2
Sponsor: Westside AV
Is phantom power on?
Old February 19th, 2010, 01:18 AM   #3
Yes phantom is on. In auto mode everything is fine. In manual mode sound has gone, very strange.
Old February 19th, 2010, 04:31 AM   #4
mabey because AUTO mode can really crank up a low signal, so your expecting there to be a lot more there when you switch to manuel. listen closer, mabey it is working and you just need to adjust things different?
because it really isnt a Phantom powered mic, even if you thought it was, and you didnt change the internal battery in it?
You got it off ? :-)
----------------sig-----------------
Re-learning everything all over again, one more time.
Marty Welk is offline   Reply With Quote
Old February 19th, 2010, 05:07 PM   #5
If you are using only one mic - it must be plugged into Ch 1.
In the audio input menu scroll down to the bottom and choose "Ext Channel Select" & set it to "Ch 1"
Then in Audio Output set your Monitor CH to "CH-1"
Have all switched on the back of the camera set to manual.
Should be good. Report back with your results.
My Work: http://www.youtube.com/ChadWork1
Sony FS5 :: Panasonic GH4 :: Sony PMW-EX1 :: FCPx :: AT4053b :: Rode NTG-3,
Chad Johnson is offline   Reply With Quote
Old August 4th, 2011, 10:31 AM   #6
Re: Ext audio missing on EX1 manual setting?
Thank you for the info - it worked. Somehow 18 months has gone by and I have just had the same problem! The camera has just come back from Sony so things had changed. Anyway now the problem has been solved. Must respond sooner in future!
Old August 7th, 2011, 07:10 AM   #7
I recently had a similar problem when I got the camera back from Sony. Turns out they had jammed the switch when they installed the rear cover.
John
John Peterson is offline   Reply With Quote
Old August 8th, 2011, 09:28 PM   #8
Jeez, three years later and they are STILL doing this c**p!? They did the SAME thing to my EX1 when they were replacing the rear plate due to the paint wear issue. Wow.
Old August 10th, 2011, 09:25 AM   #9
on the top handle there are two screws undo them inside you find a little circuit board make sure that is connected properly.
Otherwise could have problems with xlr's wear and tear maybe?
Ollie Walton is offline   Reply
