Need Help: Doing a WebCast Shoot with the EX3 at DVinfo.net
Old June 3rd, 2010, 01:20 PM   #1
hello all...
I am doing a internet web cast with my EX3 next week and I need to know the following:
The client wants me to give them a video/audio signal via the firewire cable out put...can this this happen on the EX-3 if I put the output of the fire wire on "HDV" mode? As I will then hook up that cable to a Mac Book Pro that will "broadcast" the signal to the servers.
I do this all the time, on net shoots, using my Sony V1u, but this will be the first time I am using my Sony EX-3, as thats the camera the client wants to use.
Many thanks....
Bill Griffin
SONY PXW-X320,PMW-300K2, LiveU LU-500,Sound Devices 552 Mixer,www.Dallascamguy.com
William Griffin is offline   Reply With Quote
Old June 3rd, 2010, 07:10 PM   #2
Thats right. If you put the camera in HDV mode you will have video at the firewire port. That should work fine. We do that with the EX1.
http://www.LandYachtMedia.com
Old June 4th, 2010, 08:40 AM   #3
Does this also give me audio?
As I will have a Shure FP-33 mixer with a wireless mike plugged into the audio input, which I will then put on the main speaker, then I will plug the output of the mixer into the audio inputs of the camera. I think this should work giving the fire wire output a video and audio signal.
Am I right?
TIA
Bill Griffin
Old June 5th, 2010, 05:54 PM   #4
firewire ...
I have not used this process because of the HDV codec but there should be problem doing so. The only question remains is whether HD/SDI is blocked while using firewire. I seem to recall that you can't use both at the same time. You might think about a HD/SDI breakout box instead of the HDV firewire hook-up on the EX3 for better quality in your relay. AJA or Matrox units would be good to look at.
Sony EX3, Panasonic DVX 100, SG Blade, Nanoflash, FCP 7, MacBookPro intel.
http://www.deanharringtonvisual.com/
Dean Harrington is offline   Reply With Quote
Old June 5th, 2010, 06:08 PM   #5
the client wants a firerwire out put....now I need to know, will it also output audio as well?
thanks
Bill Griffin
Old June 5th, 2010, 07:16 PM   #6
Sponsor: Abel CineTech
William,
Just set your recording mode to SP and turn HDV iLink output on. Then the camera will act like your V1u and stream out HDV video.
Andy
Andy Shipsides -Camera Technology Specialist
AbelCineTech, New York - Visit our Blog - http://blog.abelcine.com
Andy Shipsides is offline   Reply With Quote
Old June 5th, 2010, 08:53 PM   #7
I just had a similar shoot- however my client wanted webcast output in SD (I dunno if there's many webcast options in HD). So I outputted in SD via the RCA connection and connected that to my DSR11 DV deck and used the firewire output from that to give the webcast guys. I don't think HDV will play well with anything streaming, but I could be wrong...
Christoph Gelfand is offline   Reply With Quote
Old June 5th, 2010, 09:07 PM   #8
They want firewire to output to a laptop.... they say they have done this before, but I want to be safe, not sorry.
Bill Griffin
Old June 5th, 2010, 10:23 PM   #9
HDV will certainly work for live streaming if all you have is firewire in to your computer or streaming device.
I've used HD-SDI into MXO2-LE to my MacPro and my MacBookPro without issue though. HD in of any type doesn't stop you from streaming SD.
Old June 8th, 2010, 04:42 PM   #10
Big Problem: webcast shoot, video but no audio...
Hello all....
A few days ago I posted a thread about me doing a webcast shoot, well today was a set up day and for some reason my Sony EX3 would put out a video signal, but no audio. The camera is set to 1080i at SP mode (HDV) and the fire wire is set to enable..but all we got was video...NO AUDIO.
when I charged out the cameras from the EX3 to my Sony V1U....its all worked. I am plugged into a Mac Book Pro, using I-chat, as thats what the client wants to use. Also, in the EX3 viewfinder, the I-link logo would not come up, as it was suppose too, as the book says......
so the question is....why no audio from the fire wire port from the EX3? any ideas....
thanks
Bill Griffin
Old June 11th, 2010, 02:24 PM   #11
HI, Bill
I recall going out firewire once from the EX-3 and I did get audio.
Unfortunately, my EX-3 is out for the weekend so I can't test it now.
Ned Soltz is offline   Reply With Quote
Old June 11th, 2010, 07:36 PM   #12
Hello Ned,
It turns out that my EX3 and the fire wire works just fine.....I hooked it up to my V1u and put the ex3 on HDV mode....and both cameras saw each other. when I record on the ex3, the v1u will go inito record also via the fire wire cable. But the EX3 has to sense a true I-link connection in order it to work the right way.
the cheap client used I-Chat on his mac in order to save money on a sat truck and the camera did not like the link that the mac fire wire was sending. But now I know it works as I have a client that likes HDV, but wants a tape...now I can shoot on the ex3 and then make a dub.
One thing I did notice that there was about a 1 second delay in audio to video, going from one camera to the other...I guess that is normal.
Bill Griffin
