View MP4s with Windows Media Player? at DVinfo.net
Old September 21st, 2010, 10:48 PM   #1
Is there a way to view XDCAM MP4 files throught Windows (7) Media Player? I can see many different types of files, but the only way I have found to see MP4s is through Premiere, FC or Sony's Browswer... but there are times that you just want to see a thumbnail of the vid, and that seems impossible right now.
Any way to do this?
Lloyd Ubshura is offline   Reply With Quote
Old September 22nd, 2010, 07:03 AM   #2
I don't think there's a plugin to support MPEG-2 in .mp4 wrapper for WMP. You can use VLC though. There's a plugin you can buy from CalibratedSoftware which will allow you to see those mp4 in Quicktime Player.
Old September 22nd, 2010, 07:46 AM   #3
Interestingly, WMP will play the MXF for NLE as re-wrapped by the ClipBrowser - even though it displays the message (which you can disable) about not recognizing the format...
But this is limited to the native EX files; the mxf's coming from the nanoFlash do not play in WMP.
As Craig said: VLC is the answer (for both mxf and mp4).
Old September 28th, 2010, 04:43 PM   #4
2 years ago you could download MXF Desktop at Snell & Wilcox (they are not into to filmbusiness), but now I can't find it on their site.
I enables Windows Mediaplayer to play MXF-files.
Search the web for MXF Desktop and you will find a solution!
Brainstormnavigator searching for the hole in the sky.....
Audiovisual Designer (NL) - http://www.brokxmedia.nl
Walter Brokx is offline   Reply With Quote
Old September 28th, 2010, 04:44 PM   #5
Get the VLC Media player. It should play MP4s.
Chris J. Barcellos
