PMW-200 Flange Adjustment at DVinfo.net
Old July 1st, 2013, 02:42 PM   #1
After the 'FW Update drama' ended successfully (Thanks Doug!), my next task was to calibrate the 'flange focal length'. Using the Sony supplied "Star Chart (PDF)", I mounted the 'chart' on a piece of foam core board, taped it to a wall, set-up a light source and then my camera. After 'zooming-in' and filling the screen with the 'Star Chart' and locking down the camera, I performed the following steps in-accordance with Sony's instructions provided with the Firm Ware upgrade:
1) Power on the Camera
2) "Iris Switch" to "Auto"
3) Mount 'Star Chart' ~ 3m (10-ft) from camera
4) "Zoom Switch" to "Servo"
5) Go To "Menu" > "Camera Set" > "Auto FB Adjust"
6) Then, > "Execute"
That's it! If, you've set everything correctly, the camera will cycle through an automatic calibration routine. Finally, a confirmation message (or, Error Message!) will verify the 'calibration' went 'OK' (Or, not!).
I now have successfully upgraded my PMW-200s Firm Ware and performed the 'Flange-Back Focal Length' calibration and my camera is not a 'brick'. : )
It's my first time through the FW upgrade 'process' with this camera and after reading horror stories about folks turning their cameras into 'paperweights', I was a little nervous. Thankfully, with a "...little help from my friends.", I succeeded!
I hope this will help if someone is struggling with their 'PMW-200' FW upgrade.
Thanks for playing along,
J.
James Kuhn is offline   Reply
