#16 |
Re: PMW-300 Questions
The PDF Q&A provided by Sony did state it was 100MB/s. If this was I-frame only, this means no 50p/60p in 1080. Long GOP is a different story though. Sony wasn't specific when describing the XAVC recording capabilities.
#17 |
No benefits with an external recorder when XAVC 10 bit is on the camera!
#18 | |
#19 |
BTW, does anyone has any experience with the Convergent Design Odyssey 7Q,
as a recorder and as a field monitor with the EX-3/EX-1? |
#20 |
One more question:
Will the SDHC adapters be able to record 50 mb/s 4:2:2 in the PMW-300? |
#21 |
No, because SDHC/SDXC uses the FAT32 file system and 4:2:2 specifically requires the UDF filesystem.
You can use XQD cards which do support UDF, and provide similar performance to SxS with future proofing for Sony's 4K offerings down the line. |
#22 |
Thank for the info!
#23 |
Hi all,
Just to update on the XAVC question for the PMW-300. Spoke with Hugo Gaggioni Sony's Chief Technology Officer for the Broadcast and Production Systems and the official word on this is this: "The chip can do long or intra. The 100 Mbps is only for those regions in the world that would like to code 50 or 60Hz interlace in intraframe manner. We will introduce 100 Mbps intra during the summer first and then introduce 35/50 Mbps long GoP in the fall." In relation to weather this upgrade will be free (as with the PMW-400) i was told it is TBD (to be decided) Hope that is of some help to you. Last edited by Michael Hourigan; January 15th, 2014 at 11:46 AM. Reason: typo |
#24 |
Equal Opportunity Offender
Michael, thank you very much for that.
Any chance you can hit him up for the PMW-300 manual being available online? I'd like to read through it in detail before so much as bothering a camera sales rep. Andrew |
#25 |
Hi Andrew,
The manual is available (as far as i know) on the support section of the PMW-300K1 page on the Sony website. Check out this link: PMW-300K1 (PMW300K1) : Support : United Kingdom : Sony Professional Last edited by Michael Hourigan; January 18th, 2014 at 08:40 PM. Reason: typo |
#26 | |
#27 |
#28 |
For those that it may be of help, the PMW-300 K1 operations manual, saving you from logging in to a web site to be able to access it.
Andrew |
