FS5 playing with PPs and some grading at DVinfo.net
Sony XDCAM PXW-FS7 / FS5
Old December 10th, 2015, 04:09 PM   #1
Sponsor: Westside AV
Just playing with PPs a bit. First shown w/o grading, then with grading, in FCPX using ColorFinale and some basic correction then adding REC 709 Tetrachrome 400 FC LUT at 60%.
I also added the Orisis Vision 4 LUT in the end just to see how it pushes around for fun.
This was shot XAVC-L 1080 30P on the FS5 with a Canon 50mm EF f1.4 @1.4 Metabones V4 latest FW.
Old December 10th, 2015, 05:02 PM   #2
Re: FS5 playing with PPs and some grading
Olof, did you mean, it was shot XAVC-L? FS5 does not have XAVC-I codec option, as far as I know...
Thank you.
Ilya Spektor is offline   Reply With Quote
Old December 10th, 2015, 05:22 PM   #3
Sorry I used a lower case L (l), I will fix it. I am so used to writing XAVC-i from using the FS7.
It does look almost the same as capital i (I).
