Varizoom Universal Stabilizing Arm & Vest at DVinfo.net
Old June 14th, 2010, 07:56 PM   #1
Hello all,
I have a Glidecam 4000, I use with a 5D dslr
and I want a vest & arm to fly it for longer shoots.
I m on a budget and Varizoom makes a Universal Stabilizing Arm & Vest that evidently works with the Glidecam
VariZoom Dv Sportster, Navigator arm for Steadicam Merlin, Glidecam 4000, 2000, FlowPod, Steadicam JR
but I am not sure about the gimble on it
I could go with an old Smoothshooter arm & vest, but even that is double the price
any thoughts?
Other ideas are more than welcome
John
John Benton is offline   Reply With Quote
Old June 15th, 2010, 03:18 PM   #2
I'd say go with the dual smooth shooter arm instead. It behaves better than the ones you mentioned.
Charles
'What we perceive to be may not be what we believe to be.'
Charles King is offline   Reply With Quote
Old June 15th, 2010, 04:43 PM   #3
Hi John
I agree with Charles ..the dual arm will be way better..I have had both!!
If you do settle for a single arm and vest then as a temporary solution until your budget recovers, grab a CineCity single arm and vest off eBay ..they have 'em for under $500 and are basically a copy of the Varizoom vest and arm but not as well made.
I know even a used Shooter vest will cost you a mint but just bear in mind that you get what you pay for!!
Chris
Old June 15th, 2010, 10:03 PM   #4
Yeah...I know, but the Smoother Shooter is a single arm...
Are there any cheaper double arm systems?
Ugh
Thanks guys,
J
Old June 16th, 2010, 12:49 AM   #5
Hi John
Sorry my mistake!! I had the X-10 arm in my head and thought they were both classed under the smooth-shooter banner!!
The Single arm is way more robust and well engineered compared to the Flycam arm but then again it's 3 times the price.
Unless you have a LOT of gear surely you can manage a DSLR handheld. Trust me, a vest and arm is a pain to setup unless you have lots of time!!! I stopped using a vest at wedding shoots as the shoot ended up being shorter than the setup time and a big dual arm system can't really be used inside a well packed Church!!!
People with DSLR's seem to be having great success with the BlackBird rig?? Maybe sell the sled and buy just one of those???
Chris
Old June 16th, 2010, 01:22 AM   #6
Another option is the Indicam (indicam.com) system, they sell the vest and arm separately and it is compatible with the Glidecam.
Charles Papert
www.charlespapert.com
Old June 23rd, 2010, 09:38 AM   #7
Thanks Charles.
John,
You mentioned you weren't sure about the "gimbal on it". The gimbal is on your sled (Glidecam in your case) and not the arm. You probably meant different.
Remember that you will use your stabilizer through many different cameras so get a good one. It's like getting a good computer monitor. You go through many different computers but still keep the same monitor if it's good.
Tery
He's only mostly sDEADy.
sort of from "The Princess Bride"
www.indicam.com
Terry Thompson is offline   Reply With Quote
Old June 23rd, 2010, 09:42 AM   #8
Thanks Terry.
Yes you are right on both accounts.
because I am using it for DSLR shooting, I was thinking that a smaller rig might be ok. I am looking deals on a smooth shooter vest & arm... hard to find.
J
