-   Stabilizers (Steadicam etc.) (https://www.dvinfo.net/forum/stabilizers-steadicam-etc/)
-   -   Best way to shoot this.....Steadicam or Gyro Stabalizer DS1 Beholder or PilotFly H2 (https://www.dvinfo.net/forum/stabilizers-steadicam-etc/531955-best-way-shoot-steadicam-gyro-stabalizer-ds1-beholder-pilotfly-h2.html)
Silas Barker May 27th, 2016 03:20 PM
I have a client who wants to create a video similar to this one: (specifically the actual singing parts and violin parts; moving camera)
The shots are really clean. I have a Glidecam 4000 pro that is pretty old, and I am pondering getting the Beholder DS1 or Pilotfly H2..........or something else?
What would your suggestions be for creating similar moving shots (filmed with a Canon 5D).
P.S. Looks like some sort of steadicam at 1:55
Edward Carlson May 27th, 2016 04:22 PM
Re: Best way to shoot this.....Steadicam or Gyro Stabalizer DS1 Beholder or PilotFly
If you already have a Glidecam, then use it. Unless you want an excuse to buy a handheld gimbal stabilizer.
Silas Barker May 27th, 2016 04:38 PM
The Glidecam 4000 pro is about 10 years old and now that I am using DSLR mainly to shoot, I was wondering if there are any benefits to the new stabilizers out there?
Specifically if the results are good with a prime lens with no IS (glidecam 4000 is only a 2 axis gimbal and does not reduce jitters completely)
Edward Carlson May 27th, 2016 04:49 PM
And Steadicams are still used on most major films despite being invented in the '70's
It does reduce jitters if used by a skilled operator.
Silas Barker May 27th, 2016 04:59 PM
It looks great with IS but not quite perfect without it - at least at my skill level.
What about the gimbal stabilizers? Do they work good without IS lenses?
Edward Carlson May 27th, 2016 05:04 PM
Yes, the Movi and Ronin are used extensively with cameras with PL mount lenses. They do a great job.
It sounds like you want me to tell you that a gimbal stabilizer is better than a Glidecam. I'm not going to do that. I think that in the right hands, a Glidecam or Steadicam is a wonderful tool. The same goes for a gimbal stabilizer. Either one would work for the type of video you referenced. But not just anyone can pick one up and make a perfectly smooth video. The decision is yours.
Silas Barker May 27th, 2016 05:12 PM
I have had really great results with the Glidecam 4000 and larger cameras like the Sony Z1, Z5, etc
Maybe the Glidecam 4000 is too large for a DSLR
Edward Carlson May 27th, 2016 05:16 PM
Nope, the 4000 is fine for a DSLR. We have the XR-4000 (the updated 4000) that we fly a 60D on.
Here's an example:
https://www.instagram.com/p/BDzCPPzP-TL/
Matt Sharp May 27th, 2016 09:22 PM
It looks like they're using a Glidecam XR at about 1:56 in the video. There's your answer right there.
Noa Put May 28th, 2016 12:24 AM
What about shooting in windy conditions, a small glidecam is fine indoors or outdoors but becomes near useless outdoors when there is too much wind, a gimbal stabilizer will stay level no matter what.
Another advantage is better tilt and pan control, I can make moves that are either very difficult or just impossible to do with a small steadicam.
The main problem with these gimbal stabilizers is getting jitter out of the footage which is because of wrong parameters in the gimbal software so that means finetuning and a lot of testing until you get it right, only, I have not found any good tutorial that explains in detail what each setting exactly does and you need to know that before you start messing with the numbers.
Donald McPherson May 28th, 2016 02:52 AM
Never having used one. But would a vest improve things?
Silas Barker May 28th, 2016 12:19 PM
I have never used any of the Gyro / Gimbal stabilizers but I am wondering if they need more time on the market to improve some of the problems that I hear about? I went to BH video and looked at the Beholder DS1 and there are a decent amount of people retuning that product. The Pilotfly H1 only has about 3.5 star rating in reviews with customers returning or disappointed in them. Hoping that the Pilotfly H2 will be better but its not available yet. Or maybe its the camera / lens set up that is not compatible with every stabilizer?
Silas Barker May 28th, 2016 12:21 PM
so I have only used the Glidecam without a vest, no sure if the vest is a huge improvement or not. Have gotten spectacular results without the vest using cameras like the Sony Z1, Z5, Ex1r etc.
I may need to rebalance and clean the system since its not quite perfect for my DSLR, 5D right now
Slavik Boyechko May 28th, 2016 03:15 PM
I think any stabilizer would work for what you're looking to do - basically add some camera movement to a singer/musician who is mostly staying in one spot. But the benefit of the right gimbal with a lightweight camera/lens setup is you can hold it for a long time without tiring your hands/wrists. And without wearing bulky chest or arm additions.
I just shot an outside tutorial video where my camera guy pointed a Pilotfly H2 with a Canon XC10 on me for pretty much a whole day, no sweat. And no jitters. The H2 can take a higher load capacity (4.5lb) than other lightweight gimbals, but a 5D with a lens may be pushing close to that.
Mostly I've been using the Letus Helix Jr. with a C100 and 10-18mm or 18-135mm, and that combo is amazingly easy to use for long periods of time. Here's one music video where I used it for a similar reason as your music video, just add slight motion to a singer/musician.
But many gimbals are not that ergonomic and end up tiring you as much as a Glidecam, though it's your upper arm area that gets exhausted instead of your wrists. Which is why a few gimbal shooters now add an EasyRig to take the load off on longer shoots. I'd give the Helix Jr. a serious look first, and then the Pilotfly H2 or Nebula 4200 or Came-TV lightweight gimbals, depending on your camera/lens weight.
Cheers,
Slavik
Silas Barker May 28th, 2016 03:39 PM
Nice Work!
So the Pilotfly H2 has better ergonomics then some of the other gimbals out there?
I am just waiting for it to be available and see more test footage I guess. Sounds awesome so far though.
Unfortunately the Canon 5Diii on my Glidecam 4000 is heavy and hard on my back. Wish I had a lighter system. A large unit like that requires a lot of weight to keep it steady unfortunately is seems like. :(
