Just purchased DVFilm Maker at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old January 8th, 2005, 06:43 AM   #1
Just purchased DVFilm Maker & I have a Canon GL-2........do I shoot frame mode or not?
I want the non-frame for higher res. right?
Thanks in advance...
Craig Walker is offline   Reply With Quote
Old January 8th, 2005, 07:59 AM   #2
I think you don't want frame-mode. I'm not sure but it sounds like that's a in-camera de-interlacer, and since you purchased DVFilm Maker which has a much better de-interlacer you want to use that instead. I don't know what non-frame is, sorry.
Good luck,
Steven
Steven Fokkinga is offline   Reply With Quote
Old January 8th, 2005, 08:13 AM   #3
It's the 'normal' mode, which I believe is interlaced.
I'm 99% sure that's what I need, but I wanted to be sure.
I believe your comment on the 'better deinterlace' is accurate.
Old January 8th, 2005, 09:12 AM   #4
Don't use frame mode, and be sure to set your shutter speed to 1/60 sec. You should take a little time to read the online help and FAQ on their site http://www.dvfilm.com/maker/help.htm#other
The DeInterlace option seems to have no effect on my video, why not? If you shot frame mode, or used a slow shutter speed of 1/30th sec or slower, cameras like the Canon XL-1 and the Sony VX-2000 will record both fields simultaneously, and so the DeInterlace option in Maker has no effect. We do not recommend shooting in these modes because non-interlaced NTSC cannot be converted to 24 fps for transfer to film, the 24P film-motion option will also not work, and also because the slower shutter speeds will blur motion much more than a movie camera would
Old January 8th, 2005, 09:30 AM   #5
Thank you. :)
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
