White Balance and Filters at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old June 8th, 2010, 06:44 AM   #1
If you use the Tiffen Warming Black Pro-Mist (1/2) do you need to white balance with the filter off and then put it on or can you white balance with the filter on?
If it was just the Black Pro Mist (no warming) would you need to white balance with the filter off or can you white balance with it on?
TL
Tim Lawrence is offline   Reply With Quote
Old June 17th, 2010, 12:02 AM   #2
Although I have never used any filters.....I am thinking back to my days in school and filters are meant to give you a certain look so white balancing with them on would negate that look. I'd white balance sans filter then add the filter. It is the same deal if you gel a light. If you white balance then put the gel on your picture wont look right. Hope this helps.
Calvin Bellows
www.exposureproductions.ca
Calvin Bellows is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
