Inverted Video Solution at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old August 18th, 2005, 09:45 AM   #1
Images: 4
Hi iam building a mini 35mm adapter i am trying to get around the the problem of the inverted video i read that you can use a magnet and invert the video on your lcd screen my question is can this be done with the XL1 and if so how and where do you place the magnet, I know its not safe for the view finder and it could damage it but, what the hell i need a solution
James Clarke is offline   Reply With Quote
Old August 18th, 2005, 11:59 AM   #2
Record with the camera upside down.
Kevin Red is offline   Reply With Quote
Old August 18th, 2005, 12:27 PM   #3
I'm going to say that it is a very bad idea. If it can be done, it will be at the cost of the integrity of your camera. A magnetic field around magnetic tape could be the end of the world for your project. Not to mention the electronics of your camera.
You can shoot upside down, or you could try to frame the shots with them inverted. I think it would be best to just learn how to frame the shot with it inverted.
Try this: Run the camera out to your monitor and turn the monitor upside down.
DJ Kinney is offline   Reply With Quote
Old August 18th, 2005, 06:31 PM   #4
It won't work on an XL1 because it doesn't have a flip out monitor, therefore it doesn't have the need/capability to flip the image.
1. Apparently you can rotate the viewfinder to the right side of the camera (so it is upside down).
2. Or you can use an external monitor with a flip function or mounted upside down.
Note that these will give you a correct preview, but the recorded signal will still be inverted.
3. You can shoot with the camera upside down to record a right side up signal to tape, but the EVF will still show upside down, so you'd need to use it in conjunction with 1. or 2. to get a proper preview also.
You might get more response if you post this question in the alternative images forum.
Cheers.
Kyle Ringin is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
