#31 |
Re: Is this a good way to fix this rolling shutter issue?
For sure the mirror is the heart of the problem. Wait a second the A7S doesn't have mirror. maybe its too vertical
#32 |
also known as Ryan Wray
Oh but you said, that mirrorless cameras have problem with rolling shutter.
#33 |
#34 |
Oh okay, I thought that the rolling shutter jello effect, was caused by the fact that it wasn't a global shutter, unless there is more to it?
#35 |
Ryan, we gave you a little test to see if you understand what you are talking about. You failed I'm afraid. You need to do some serious study on the causes of the reasons objects look different shapes to reality when shot by cameras that use alternative capture techniques. You need to go back first to optics development in film based camera to understand the concept of mechanical shutter angles before you start looking at electronic versions. Your current problem needs breaking down properly into cause and effect, before you have any hope of being able to accurately predict the behaviour of products as yet only seen on a computer screen. Serious hard work research, study and learning. You know the words, but are using them poorly because all our comment based on you having understanding you actually don't have.
Sorry, but until you understand the physics going on here you are stuck. |
#36 | |
https://en.wikipedia.org/wiki/Rolling_shutter Interestingly, I could get a rolling shutter effect in the CRT viewfinder of a CCD camera when in progressive frame mode because of the scanning in the viewfinder. It happened when you whipped panned. You can also have the effect on some stills camera shutters. It was quite effective in giving the impression of speed in some early racing car photographs because of the skewed verticals. http://www.artnet.com/artists/jacque...YzDwkoUZvXPhQ2 Last edited by Brian Drysdale; September 4th, 2020 at 01:32 AM. |
#37 |
You just made me think Brian. I did a series of promo work for a parachuting company last year and used a B4 lens on my JVC 750 to get the extra reach to fill the frame with the aircraft at dropping altitude. The first weekend revealed lots of physical issues - mainly my inability to do a 360 around the tripod legs with my eye to the viewfinder, because in bright sunlight the flip out viewfinder was wiped out. I bought an ultra bright external viewfinder with SDI in and side mounted this so I could pan and tilt standing back, and it was brilliant. However you just hit on the reason for the strange treatment of the trees when they got close to the ground and the trees and horizon objects started to appear in the viewfinder framing.In the video files it's perfectly fine, but in the new monitor, very strange artefacts. It didn't matter at the time because the footage was fine, but I bet this is related to your discovery. Sort of a scan of a scan of the frame.
#38 | |
#39 |
