What kind of shots should I use BLUE SCREEN then GREEN SCREEN? at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old November 8th, 2005, 01:30 PM   #1
Are outside shots for special effects GREEN SCREEN and BLUE SCREEN inside. I'm curious as to what color to shoot in front of for certail special effects shots.
James A. Davis is offline   Reply With Quote
Old November 8th, 2005, 02:57 PM   #2
you have to consider if your subject has blue or green colors on it such as eyes, clothes etc.
I guess that those 2 colors you would find the least than other colors on human being.
It's a matter of picking a different color than your subject, has nothing to do with indor or outdor shots.
Viktor Bludov is offline   Reply With Quote
Old November 8th, 2005, 04:22 PM   #3
outside , you got the (sometime) blue sky, so it can be a problem.
Many people wear blue (bluejean, tie, shirt), but you will rarely see the flashy green for keying anywhere.
blue when dark goes easily to black, when green stays. shadows are easily manageable with green.
You can correct green spills with orange light on subject.
Correcting blue spills is a bit harder.
With DV, anyway green is better, so if you choose green you will encouter anyway less problem.
Old November 9th, 2005, 06:18 PM   #4
Any color can be used for keying. The Matrix Reloaded used some purple screen. Tracked model shots used orange in Voyager. With people, you generally want to stay away from warm colors as they are the components of flesh tones. Cameras are made to give green better detail as our eyes are the most sensitive to it. Blue and green were originally used as it was easy to seperate with an RGB signal.
Adam Keen is offline   Reply With Quote
Old November 30th, 2005, 05:23 PM   #5
Blue was the original color for keying, just because blue is not in any human skin tones. Green is in some skin colors, but green is better for Digital Video. You could even use red if you choose to.
Pay attention to what is in front of it more. For example blonde or white hair does not key well, so maybe those persons could or should where a hat. White clothing is also difficult also. Contrast is a consideration all the time.
Light your subjects correctly and watched how they are dressed. Overall, green is better for digital video, and most color keying is best done inside under controlled situations, then you can add any background you choose.
Best of luck--Mike
Chapter one, line one. The BH.
Mike Teutsch is offline   Reply With Quote
Old August 23rd, 2009, 04:51 PM   #6
Green Screen setup help
what is the best way for me to change the lighting setup in this studio for the green screen and actor thanks ? file:///C:/Users/Mrlove/Pictures/2009-08-02/022.JPG
Tamim Amini is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
