How to reduce depth of field on HC1 at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old September 8th, 2006, 08:39 AM   #1
Hey guys.
Would anybody have any tips on how to reduce depth of field using a Sony HC1 camera?
I've been trying in on the maximum "tele" zoom with "2 to 5 metres" distance to the subject and it works good specially for macro shoots.
I was wondering then if anybody would have any idea on how to do an interview (close-up shot) with a blurred background....
Where to position the talent, distance from the camera and from the background....
Thanks, guys.
PP
Pedro Paiva is offline   Reply With Quote
Old September 13th, 2006, 04:14 PM   #2
Shallower depth of field is controlled in a few ways.
1. Zoom in on subject. Telephoto lenses have a shallower DOF than wide-angle. Move back from the subject and zoom in.
2. Open aperture all the way.
3. Move subject further away from background.
Of course you'd need a big room to use all of these techniques, but they're guaranteed to work.
If the room is too tight, the easiest way is to fake the DOF. Make a garbage matte in FCP or Premiere with a blur on it to simulate the depth, or in After Effects duplicate the layer and create a mask with a blur to achieve the look. I've done this before with satisfactory results.
Joe Winchester is offline   Reply With Quote
Old September 13th, 2006, 07:05 PM   #3
I believe a Neutral Density Filter will make the depth of field more shallow as well.
Justin Tomchuk is offline   Reply With Quote
Old September 14th, 2006, 11:07 AM   #4
Another solution is to shoot the foreground in front of a green screen, and composite in front of a blurred background.
Jon Fairhurst
Old September 14th, 2006, 02:35 PM   #5
A letus35a will work if it can be used with HC1. I am not sure.
http://www.letus35.com/letus35.html
Richard Zlamany is offline   Reply With Quote
Old September 14th, 2006, 05:32 PM   #6
Hawaiian Shirt Mogul
use a foldable green screen behind the person then when you add the background blur it !!
Don Donatello is offline   Reply With Quote
Old September 27th, 2006, 06:57 PM   #7
Do like Joe writes. That's the common procedure.
I've done som masking too in After Effects, also with nice results. There are some plugins out there that simulates the blur of camera lenses, better than any of the built in blurs in AE.
I you plan to mask, make sure that the scene is as static as possible, masking a scene with motion is a pain.
This is done in AE, and it is NOT very static. Had to do some serious stabilizing before... By the way, it hasn't had any cc or noise reduction.. :)
http://www.nattvard.com/upload/aedof.mpg
Carl Jakobsson is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
