What's the facination w/ a set of Nikon lenses? at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Techniques for Independent Production
The challenges of creating Digital Cinema and other narrative forms.
Old May 15th, 2007, 04:36 PM   #1
Please pardon my ignorance here, but when it comes to adaptors mounting on to camcorders, why do folks graviate towards Nikon lenes over say Canon lenses? Is it because the lenses sensor size is more compatible with 1/3 chip size sensor?
Thanks for clearing this up for me.
R.W. Swanson is offline   Reply With Quote
Old May 15th, 2007, 05:29 PM   #2
Nikon optics have been long accepted as among the best in 35mm photography, and that is carried over to the image it produces for adapter purposes. I think it is as simple as that. Canon has a good reputation too, but I have to say the putting the build of the one Canon I own against the 3 Nikons, results in a win for Nikon. But this is only anecdotal, and I am not saying that means anything....
Chris J. Barcellos
Old May 15th, 2007, 05:34 PM   #3
Most Canon FD lens will not stop down below full aperature unless attached to a Canon camera.. other than that, for use on a system that is projecting an image on a spinning groundglass, there isn't much difference.. I have both.. the thing I don't like about Nikkors is that they focus backwards compared to all other lenses (clockwise for infinety). Pentax or Minolta lenses would be fine too, but old used Nikkors are in abundance, cheap - at least here on the west coast of the US
Steve Rosen is offline   Reply With Quote
Old May 17th, 2007, 03:45 PM   #4
I would actually think Zeiss Planar T lenses would be most ideal for 35mm adapters. They are in the same price range of new Nikon/Canon lenses and have a Nikon mount, but most importantly, they are color matched (according to Zeiss).
So you can have a SET of lenses that all give the same color rendition. Acquiring a set of color matched Nikon or Canon lenses is a hit or miss (mostly miss) proposition from what I understand.
BTW, I have not used a 35mm adapter myself. This is just what I've gleaned from studying up on them.
HTH, and is accurate.
Old May 17th, 2007, 04:46 PM   #5
Not to mention that Nikon has used the same mount for many, many years and so it is easy to build an adapter with an f-mount that can use old and new lenses. Plus they're cheap. :D
Mike Oveson is offline   Reply With Quote
Old May 18th, 2007, 09:12 AM   #6
One more thing - actually, the main factor in my decision - the new Zeiss lenses made for Nikon mount.
And the same thing, but more. When I was earning my rent doing stills, I traveled and shot a lot. My senior partner ran Nikons and so I ran anything but. I started with screw mount Pentaxes, then Leicaflexes, then Canons, then Olympus OM...
Eventually I was still running them all, but also ran Nikons because of the sheer quantity of lenses and bodies available around the world at a decent (non collector's item) price.
Nowadays, I'm in film mainly, but I still retain my Leica M2, a set of medium format gear - and a full set of Nikons.
Chris Leong is offline   Reply
  You are here: DV Info Net > Special Interest Areas > Techniques for Independent Production
