Adobe Photoshop at DVinfo.net
Old May 27th, 2003, 01:01 PM   #1
Adobe Photoshop
I just got Photoshop 7.0. Granted I'm not the sharpest pencil in the box when it comes to working with products like this. I tried for an hour to resize a picture with no luck. I tried to follow the help.haha. No such luck. I'll never figure out whay to do or what i could do with this. I wish there were tutorials written for idiots.
Charles French is offline   Reply With Quote
Old May 27th, 2003, 01:09 PM   #2
Hello Charles,
Here are some URLS that can help you.
http://www.photoshopcafe.com
http://www.photoshoptechniques.com/
http://www.Photoshopgurus.info/
If you need more let me know ;)
Hope this helps!
Thank you for sharing your world with
me.
William Velasquez is offline   Reply With Quote
Old May 27th, 2003, 01:18 PM   #3
Take heart, Charles. There are oodles of books on Photoshop available at Amazon, or, better still, your local book store, where you can hunker down with them and decide which one looks best for your level.
And yes, I believe there is a "Photoshop for Dummies."
You are in for a long and bumpy ride, so relax and enjoy the journey.
BTW, to change the size of a picture, go to "Image" pulldown, then select "image size." Simply replace the image size information with the size you would like, and press OK. Now, if what you mean is you want to "crop" the image size, that is another matter.
Wayne
If it was easy, they'd get a relative to do it.
Wayne Orr is offline   Reply With Quote
Old May 27th, 2003, 08:03 PM   #4
Warden
I teach a Photoshop course and workshop at the school I teach at. If you get stuck, email me and I'll help you through it.
Jeff Donald
Carpe Diem
Old May 28th, 2003, 12:38 PM   #5
Thanks guys as usual you all have helped. What I cant figure out is , if I want to enlarge to a 8x10 in pic I cant just put in 8x10 it dont work that way. I dont know the calcalations for this.
Old May 28th, 2003, 12:48 PM   #6
I only have version 6, but I assume the same is true for 7:
[list=1][*]From the menu select Image > Image Size...[*]In Document Size, select 'inches' in the drop-downs and then add the dimensions in the left-hand boxes.[*]Select other options as appropriate.[/list=1]
Nigel Moore is offline   Reply With Quote
Old May 28th, 2003, 01:08 PM   #7
Hmmmm thought I tried that but upon preview it would not resize. I donno I'll keep tryin. tks
Old May 28th, 2003, 01:31 PM   #8
Bear in mid that that approach may not change the size of the document on the monitor, but will change the size for prionting.
What are you intending to do with the image? If it's for screen output, inches have no relevance at all.
Old May 28th, 2003, 04:02 PM   #9
Warden
Charles are you on a Mac or PC?
Jeff Donald
Carpe Diem
Old May 29th, 2003, 06:43 AM   #10
I'm usin PC. I was just trying to enlarge a picture and print. I've taken some stills with my VX2 onto memory stick and put in PShop. I was told the quality of these would't be as good as they can be taken in progressive scan. I'm trying to work that out too. But thats another long story.
I've noticed I have Photoshop & Image Ready, can someone tell me the correlation of the two.
tks, charles
Old May 29th, 2003, 11:48 AM   #11
Air China Pilot
Image Ready helps get your picture ready for the web. It optimizes and slices and can make animated gifs, rollovers. I often use Image Ready interchangeably with Photoshop because they share many of the same tools. However, Photoshop has the more advanced toolset. Photoshop does not have the web tools that Image Ready has.
If you want to make your capture ready for printing, there is not much you can do about enlarging its dimensions without degrading its image. 720x480 is what you have to live with. If you scale it up it will lose its resolution.
Visit http://www.KeithLoh.com | stuff about living in Vancouver | My Flickr photo gallery
Keith Loh is offline   Reply With Quote
Old May 29th, 2003, 12:27 PM   #12
Warden
How to resize in Photoshop. I am on a Mac but for these steps the labels should all be the same.
1. Open image in PS File>Open
2.Go to Image>Image size
Image Size Dialog window should be set as follows:
Pixel dimensions>Pixels
Document Size>Inches
Resolution>Pixels Per Inch
Constrain Proportions should be checked
Resample Image should be checked
Resample>Bicubic
I would not go larger than a 5 X 7 image. A 4 X 6 will yield better quality.
Lets make a 5 X 7:
Under Document Size change the shortest dimension to 5.0 inches. The longer dimension will automatically resize because constrain proportions is checked.
Now change resolution to 300 pixels per inch. If resample image was checked the size should stay the same (5 X 7 something).
Click OK
Image is now resized for printing a 5 X 7.
But we're not done yet.
Go to View>Print Size and you'll see a 5 x 7 on your screen.
But we still aren't done.
Go to Filter>Video>De-Interlace
A dialog window will appear.
The following steps are needed only for interlaced video images. If you image looks jaggy do the following steps.
Choose odd fields
Choose interpolation
Click OK
The image is now ready for adjustment using Image>Adjustments>select operation
The very last step, no exceptions, is to sharpen the image. Do Not Use Sharpen etc.
How to sharpen for print:
Go to Filter>Sharpen>Unsharp Mask
As a starting point use the following in the Dialog window.
Amount: Between 50% and 150%
Radius: Between 2 and 4
Threshold: Between 4 and 11
Sharpen needs to be the very last step. Make no further adjustments after sharpen.
Choose Print and set printer for Best quality Photo Printing with photo quality paper and set printer resolution for the highest quality. Print.
Do Not expect photo quality images without a photo quality, 6 color printer. If quality is less than expected, reduce size to 4 X 6. Buy 6 color printer, buy photo quality paper, do not use generic inks or paper.
Post back questions or results. Thanks.
Jeff Donald
Carpe Diem
Old May 29th, 2003, 12:40 PM   #13
Damn! Got It!
Old May 29th, 2003, 04:39 PM   #14
Warden
Well, how do they look?
Jeff Donald
Carpe Diem
