Benro Tripods? at DVinfo.net
Old May 11th, 2006, 01:29 PM   #1
Benro Tripods?
Hello,
I am new to the forum and new to any serious outdoor video work. I own a GL2 and plan to use it for wildlife videos (which will require backpacking in some cases).
I am curious if anyone has used a Benro tripod specifically the C-297 with offset center column or the C-228.
I am trying to avoid spending the bucks for a Gitzo, but I may have to. The other option may be a Manfrotto 055MF4.
Your comments would be very much appreciated.
Thanks in advance.
Sterrett Smith is offline   Reply With Quote
Old May 17th, 2006, 08:46 PM   #2
Thanks, problem solved
I solved my problem: I bought the best, a "lightly used" Gitzo 2228. I figured I might as well spend the bucks and get the best and not be sorry. I bought a used Gitzo for a few more bucks than a new Bogen/Manfrotto, but I should not get hurt too bad if I ever decided to sell it.
I'm excited to try it and see how it performs.
Thanks to all those who looked at my post.
Sterrett
Old May 18th, 2006, 10:34 AM   #3
Gitzo
Hi Sterret
You will never be sorry. I have a 1327 carbon and have hauled it all over the planet. It is indestructible, extremely stable and Light which really makes a difference, especially after carrying it all day. The legs are under 5 lbs, and with a fluid head and bowl adapter it is about 9 lbs. Lot lighter than almost the 14 lbs with my manfrotto.
Jack
Jack D. Hubbard is offline   Reply
