Pickup up a 22" Gateway FPD2275W monitor at DVinfo.net
Old November 25th, 2006, 10:49 PM   #1
Images: 57
Not a production grade monitor mind you, but a decent pc monitor that will also work in 1:1 as an HDTV monitor for $400. A good deal going this route vs. getting a comparable HDTV that has a PC connector, almost 50% less in cost.
Also considering that this monitor is HDCP complaint via the DVI, and the new touch screen menu on the bezel is neat. (In fact, I never had a monitor that had it's own startup sound at boot).
It also comes with software that allows you to lock it to the host PC. Should someone steal it, it won't work on another machine without your authorization.
http://www.gateway.com/programs/wide...overview.shtml
Peter Ferling is offline   Reply
