Jvc Dt-v100cg at DVinfo.net
Old December 2nd, 2006, 02:08 AM   #1
Jvc Dt-v100cg
I'm looking at this monitor, the JVC DT-V100CG both for field use and as a studio monitor.
I'm doing mostly wildelife stuff, shooting with a Canon XLH1 and Canon HV 10 as a second camcorder and for a deck.
Has anybody used this monitor and what is your opinion?
Edit: Here is a link: http://www.jvcproeurope.com/uk/pub/i...item=DT-V100CG
- Per Johan
Old December 2nd, 2006, 08:01 PM   #2
looks like low res
Looks likes it's low-res.- 300 lines? My old 400 line S-Video panasonic is better than that! BH has the specs, but something's whacko :
http://www.bhphotovideo.com
Application: Production, HDTV and SDTV
CRT Size: 10 Inch
Video System: NTSC, PAL, 480i, 480p, 576i, 1080i/30-Frame 1080i/24-Frame, 720/50p, 720/60p
Maximum Resolution: 300 Lines
Phosphor: Not Specified by Manufacturer
Color Temperature Pre-Sets: 6500k and 9300k
Input and Output Connectors: Composite Video- BNC (x 2 input, 2 output)
Sync- BNC (x 1 input, 1 output), RS-485 Control- RJ-45 (x 2)
Make/Trigger- RJ-45 (x 1), HD/SD-SDI- optional with IF-C151HDG provides BNC (x 2 input, 1 output)
Audio- optional with IF-C151HDG provides RCA (x 2 output)
HD/SD Component Video- optional with IF-C101CMG provides 3-BNC (x 1 input, 1 output)
Set-Up Features:
Underscan
Blue Gun
Color Off
Aspect Switchable
Power Requirements: 120/220-240 Volts, 50 or 60 Hz
Power Consumption: 0.9 Amps Maximum
Dimensions (WxHxD): 8.75 x 8.75 x 12.7 Inches 222 x 220x x319.3 mm
Weight: 15.7 Lbs 7.1 kg
Stephen Armour is offline   Reply With Quote
Old December 3rd, 2006, 03:40 AM   #3
Thanks Stephen,
yes I'm aware of the low res, that's way I was wondering about user experience for this monitor.
Are there any other monitors in the same price range that you will suggest? It must have PAL and up to 1080i
- Per Johan
Per Johan Naesje is offline   Reply
