Slideshow at DVinfo.net
Old May 18th, 2009, 11:17 PM   #1
Slideshow
Hi Guys,
I am planning to make a photo slideshow for a wedding. I have Adobe Premiere CS3. How can I make a a vignetting effect like this:
YouTube - Pre wedding photo montage/slideshow by GregsVideo.com/SignificantzTouch.com
Thank you,
Jun
Sony Z7U, Canon 5D Mark II, Canon 24-105 F4L, Canon 70-200 F2.8L, Canon 580 EXII, Zoom H2.
Jun Galinato is offline   Reply With Quote
Old May 18th, 2009, 11:30 PM   #2
I use Vegas for video editing, but if I am going to do a pure slideshow, I still tend to use a program JUST for that purpose... ProShow.... look at it... Pretty versatile and easy to use.
http://www.photodex.com/
Chris
Old May 18th, 2009, 11:38 PM   #3
Thanks Chris. I will try the 15 day trial.
Jun
Old May 19th, 2009, 08:09 AM   #4
What I've done before in CS3 is use the Generate->Circle effect under Video Effects. You can set the blending mode to Stencil Alpha and it turns the circle into a kind of mask for the underlying image. Then feather out the edge until you get the effect you're going for.
The circle by itself works well for 4:3 footage. But if you're working in 16:9 or wider, it's best to duplicate the video track up onto another track and then apply the circle effects on each end of the two images. In other words, on Video1 I would import my image, apply the effect on the right hand side of the image, then I would copy the clip upward onto Video2, and move the center of the circle to the left-hand side of the image.
Works pretty well. Here are the before and after for me...
kerrvillephoto.com
Photo & Video specializing in real estate and events
Aaron J. Yates is offline   Reply With Quote
Old May 19th, 2009, 05:55 PM   #5
Thanks Aaron. That's what I'm looking for.
Jun
