Pixelating on highlight vid at DVinfo.net
Old May 21st, 2009, 12:53 PM   #1
I was previewing my latest highlight wedding vid on my 50" plasma and noticed some pixelating especially between transitions. How can I avoid that? Are there certain settings I can select to get the best possible quality? I am using vegas 8.0b
Lalo Alvidrez is offline   Reply With Quote
Old May 21st, 2009, 01:16 PM   #2
What format did you edit? HDV? MPEG2? Did you render out using "Best" video quality?
Old May 21st, 2009, 03:03 PM   #3
try this
Go here and read this article, I believe you wont be able do do anything about, but good luck.
Exporting HDV Video from the Timeline to Standard Definition DVD
Walt Paluch is offline   Reply With Quote
Old May 21st, 2009, 03:46 PM   #4
I rendered to mpeg2 format using DVD NTSC template. I've done many highlight vids and never noticed this kind of pixelating.
Old May 21st, 2009, 03:46 PM   #5
One other thing
Hi again
Had to mention this, I have been having the same thing happen since allot of my customers have been watching either Blu-Ray or high def TV.
SD just does not look as good anymore to me either.
Old May 21st, 2009, 05:58 PM   #6
are you previewing real time from timeline?
try to re-render your transition. it fixed my problem in fcp.
hope it helps
Santo
If a picture is worth a thousand words, what about motion picture?
website: www.papercranes.com.au | blog: www.weddingvideosydney.net
Susanto Widjaja is offline   Reply With Quote
Old May 31st, 2009, 10:37 PM   #7
Render with high constant bit rate MPEG, not variable. It will do low bit rate on black fades, and the result is pixelation...
http://www.cip4me.com
Alex Atamanskiy is offline   Reply With Quote
Old June 1st, 2009, 11:03 AM   #8
You didn't say what format you edited with.
If you edited in HDV and are delivering in SD, then make sure that you have render quality set to Best, not Good in the render preferences.
Vegas does an excellent job of scaling, but for best results, a setting of "Best" in the render settings will yield the optimal results.
Michael
www.lvpvideo.com
Michael Liebergot is offline   Reply
