Attaching 5D to QR plate securely at DVinfo.net
Old November 13th, 2013, 07:26 AM   #1
Hi all 5D and other similar DSLR users. I only use my 5D for the evening reception but even in that short time the QR plate (manfrotto) slowly rotates and works it's way loose and I have to keep tightening it up - I'm assuming it's because the 5D only has one point of screw attachment and traditional video cams (as in my sony EA50/VG20) have that as well as an extra 'locating' pin to stop it coming loose.
Any tips to stop this happening?
Pete
Old November 13th, 2013, 07:31 AM   #2
Re: Attaching 5D to QR plate securely
Pete
Tongue in cheek here Peter, but super glue ;)
Seriously, i have the same problem and just have to keep tightening them from time to time. There is too much leverage fora single screw to hold, so give it a really good tighten and don't keep twisting it ;)
Qualified UAV Pilot with CAA PFAW
Aerial Photo / Aerial Video | Corporate Video Production
Dave Partington is offline   Reply With Quote
Old November 13th, 2013, 07:35 AM   #3
I use some small strips of bike handlebar tape. It won't leave a sticky mess, and it gives a bit more grip when you compress it down.
Brian David Melnyk is offline   Reply With Quote
Old November 13th, 2013, 09:56 AM   #4
This is the solution you seek:
Photography and Cinema - Store ATP - Anti Twist Plate for Manfrotto 501PL
Bob
Image of the Horse-Equine Photography
Bob Ohlemann is offline   Reply With Quote
Old November 13th, 2013, 10:43 AM   #5
Magic - What a good idea - ordering one right now!
Old November 13th, 2013, 11:07 AM   #6
You guys using the 501 plates? I screw mine on tight and never have issues.
DSLR Photographer/Videographer from Massachusetts
Portfolio at http://ebourcier.com
Evan Bourcier is offline   Reply With Quote
Old November 13th, 2013, 11:11 AM   #7
Thats what I was thinking as well. I have 501 plates on all mine and the little lug at the front seems to stop any spinning. I do have battery grips on all my dSLRs though - not sure if that makes any difference.
Pete
Peter Riding is offline   Reply With Quote
Old November 13th, 2013, 11:15 AM   #8
I dont have issues all the time either. It will happen once every 4-5 events but for every event I just tightened it as part of my prep checklist.
Chris Talawe is offline   Reply With Quote
Old November 13th, 2013, 11:58 AM   #9
Yep - it's a 501 and does work it's way loose - maybe I'm heavy handed! Looking closely the plate has 2 rubber strips that are sliding askew - i've tried a little superglue and as i'm filming at the weekend it will put it to the test
Peter Rush is offline   Reply
