January 26th, 2020, 03:06 PM | #1 |
Rolling Shutter
I got this banding from the venue lighting which must have been led. (dark rolling horizontal bands). Is there any way to fix it?
https://www.dropbox.com/s/jjg7xz55kd...utter.m4v?dl=0 |
January 26th, 2020, 03:31 PM | #2 |
Re: Rolling Shutter
I've experienced that before with my Z7U, playing with the shutter speed solved the issue.
Rickey https://iclickfilms.com |
January 26th, 2020, 03:59 PM | #3 |
Re: Rolling Shutter
I was renting A7iii and only had a time to try a few settings but I couldn't get the banding to stop. I just downloaded a flicker free plugin but its not working.
January 26th, 2020, 11:28 PM | #4 |
Re: Rolling Shutter
Hi gents,
You're in 60 Hz lighting territory which means that NON thermal inertia lighting is a real problem, ergo: fluorescent, gas discharge and led. So called "normal" tungsten thermal lighting does not exhibit this phenomena. If you must shoot under these conditions of non thermal inertia lighting your shutter speed must be no more than 1/60th of a second and preferably 1/30th of a second. This of course gives rise to a heap of other problems but you'll just have to get used to it. LED lighting is here to stay and is only going to get more widespread with time. Regards, CS PS: No, there's no way to fix this in post that I know of. |
January 27th, 2020, 02:40 AM | #5 |
Re: Rolling Shutter
Pete
Did you try this? It’s been helpful for me,once when I needed. https://digitalanarchy.com/Flicker/m...UaAhMCEALw_wcB
Geani66 |
January 27th, 2020, 07:13 AM | #6 | |
Re: Rolling Shutter
February 7th, 2020, 12:05 PM | #7 |
Re: Rolling Shutter
Pete, I saw this the other day & recently noticed Premiere has a 'Rolling Shutting Repair' fixing effect. I gave it a shot but it didn't seem to do very much. I looked up this video & it seems to work for something else. https://www.google.com/search?client...OD_Qb4_6bwDQ30
I know I'm late & not sure if you're done on it, sometimes different color corrections can help lessen it or make it less noticeable (lightening, darkening). |
February 7th, 2020, 01:10 PM | #8 | |
Re: Rolling Shutter
Most of the solutions I've seen are for faster banding that appears as flashing. When I did research on this I found out that the Sony A7 series is more susceptible to this slow banding because the 4k full frame takes longer to scan. Sony makes a more expensive A9 camera which I've read has a faster processor and doesn't have this problem. I've also read and my experience supports this that when consumer led lights are dimmed it increases the chances of banding. |
