Vegas taking 9 hours to render???? Why? at DVinfo.net
Old July 31st, 2007, 01:40 AM   #1
Hi,
I have just finished editing my first "Vegas" project. It was very easy to use and I was impressed overall. I am now rendering it out and for a 40 minute project it says it will take 9 hours.
I have a dualcore P4 3.2ghz with 1GB Ram. The footage was shot in hd but downconverted out of the z1p to SD during capture.
I am sure I have probably missed a button/switch/setting somewhere but not sure where to look.
Any suggestions would be appreciated.
Troy
Troy Alan is offline   Reply With Quote
Old July 31st, 2007, 02:01 AM   #2
That's pretty long for an SD render on a fast machine. The one thing that will make Vegas take absolutely forever to render is if you choose "3D source alpha" as your compositing mode on any of your tracks. If you need that effect, usually it's just on a tiny section. Render just that section that needs it in the 3D Source Alpha mode. Regular Source Alpha or any of the other modes beneath "the line" are fine.
There are some plugins that will increase render times horribly as well. "Magic Bullet" is one of these.
Laurence Kingston is offline   Reply With Quote
Old July 31st, 2007, 04:18 AM   #3
I've just finished rendering 20hrs for a 50 minute SD program (P4 2.4ghz, 1024 RAM)
Vegas is a render-hog!
Canon XM-2
AVID Xpress Pro 5.7
Merlin Vandenbossche is offline   Reply With Quote
Old July 31st, 2007, 06:02 AM   #4
actually thats not the only thing that makes Vegas rendsers take a while.
Median FX, heavy CC, Of course any Magic Bullet FX, pretty much any of the FX will suck up resources on a render.
SOLUTION: If you are going to put the finsihed product on DVD OR even WMV why not render to DV-AVI FIRST-this renders much faster thru the FX and now you have a FINISHED product that you can render out to anything you want in a much less resource heavy format. I know the MIGHT be a very very very slight degradation of quality but in all th eyears I've been doing it that way neither I nor my clients have ever really noticed it.
Anytime you take a Vegas project straight off to MPEG with lots of FXs it is going to take a really long time and frankly, IMO, the longer the machins is rendering the more chances of something going wrong. Is it just me but I hate it when the render is say 63% done and the machince crashes or the project gets hung up.
Well it's just my way of doing things but it's been working really well for me for a long time so I thought I'd pass it along.
Don
Old July 31st, 2007, 06:04 AM   #5
In Vegas preferences, under preview, change your dynamic ram setting to zero when rendering. Change it back to when editing.
Old July 31st, 2007, 07:15 AM   #6
Vegas isn't any more nor less a "render hog" than any other application. As mentioned, certain filters can cause longer renders to occur, depending on their spatial or temporal effect on the video.
Additionally, some filters are optimized better than others.
Setting RAM to 0 if you don't have a lot of stills is a good idea.
Some machines require render threads to be shifted from the default 4 to a value of 2.
It's like a car; you need to balance the engine with the rest of the equipment on the car. Same with balancing Vegas with your machine.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old July 31st, 2007, 09:27 PM   #7
Vegas is the only application (as far as I know) that will smart-render Cineform. If you are working with a Cineform project, renders in Vegas can be way faster than anything else because this.
Old July 31st, 2007, 10:53 PM   #8
Vegas renders faster than realtime if managed correctly
the comment re-magic bullet is slightly innacurate as MB2 uses GPU acceleration. Since MB2, and on anything on or over a 6800GS, u should get realtime, if not faster
in regard to renders, it really depends on what your rendering, how your rendering (ie what format) what filters are used (more precisely, in what sequence your filters are arranged per chain, track motion or event pan and crop (ie scaling) etc etc
Vegas is far from being a render hog...
I have a 3.0 extreme single core CPU with 1gb ram on one of my machines and HDV renders about 1.5 realtime
Peter Jefferson is offline   Reply With Quote
Old August 1st, 2007, 07:14 PM   #9
Thanks for all the responses. I have changed the settings as suggested and had a slight increase in render time. Still nowhere near real time or even 1.5-2x real time. It is a shame as I really enjoyed editing on Vegas. I will keep hacking away and see if I can tweak the system abit.
Thanks again.
Troy
