Easiest way to correct audio sync drift in Vegas? at DVinfo.net
Old April 24th, 2008, 07:46 AM   #1
I want to decouple the audio and video track of a clip and shift the audio track back two frames with respect to the clip. I can't figure out how to decouple the tracks. What am I missing?
All the best,
Robert K S
Search DVinfo.net for quick answers | The best in the business: DVinfo.net sponsors
Robert Knecht Schmidt is offline   Reply With Quote
Old April 24th, 2008, 08:26 AM   #2
select clip
right click
group
remove from
There is also an ignore event grouping button on toolbar
and a keyboard shortcut
maybe other ways also
Jim Ohair is offline   Reply With Quote
Old April 24th, 2008, 09:08 AM   #3
Thanks... I figured out what I was doing wrong. I had to turn off auto-ripple, too. Else, whenever I moved the audio track, the video track moved with it.
All the best,
Robert K S
Old April 24th, 2008, 09:01 PM   #4
I had a situation where I had audio from an Olypus Digital Voice Recorder WS-300M that while it will be in sync for the first 2 seconds, it will drift more out of sync the longer the audio clip is. At least to a point.
So, to get it in sync, I simply align the beginning of the Olympus audio with the other audio and then at the end of the Olypus audio I hold the CTRL key while draggin the end to match the other audio and it will be 99% in sync. There will be slight variations throughout the clip but it will be close enough.
The Olympus has a poor clock and that causes it not to stay in sync as the clip progresses.
Danny Fye
www.vidmus.com/scolvs
www.dannyfye.com
Danny Fye is offline   Reply With Quote
Old April 26th, 2008, 07:29 PM   #5
Originally Posted by Jim Ohair View Post
select clip
right click
group
remove from
You can also select the clip and press U
Jerome
www.jeromecloninger.com
Jerome Cloninger is offline   Reply
