Dynamic RAM preview (Preview-Full) limited? at DVinfo.net
Old May 30th, 2008, 04:00 PM   #1
Hey, anyone much about Dynamic RAM Preview?
When I build dynamic RAM preview in preview windows settings quarter or half, I can build very long previews, havent tested maximum but 10 seconds works...
But, when I have preview settings to Preview-Full, I can only build a 1 or 2 seconds of preview...After that the preview stops building my 6 seconds of desired preview that I wanted....
Somehow it refuse to build more like I didnt have enough RAM or something (i doubt it, it cant be the reason)...
So the Dynamic RAM Preview stops so I cant preview long enough.
I like preview-full to view my work with alot of details in.
My system specc's is:
Windows Vista x64
Intel Core 2 Duo 3.0GHz
4GB RAM 667MHz
2x160GB SATA2 Drives
I have tested it on Windows XP sp2 also, but still same problem.
My Laptop, Core 2 Duo 2.2GHz, 2GB RAM, have the same issue.
Is someone else experience this problem?
Kim Olsson is offline   Reply With Quote
Old May 30th, 2008, 04:08 PM   #2
The Dynamic RAM preview that you're doing is Ctrl+B, right? Then yes, on Full mode, only a few seconds would show up, whereas on lesser quality modes the preview would be longer.
SB
Steven Bills is offline   Reply With Quote
Old May 30th, 2008, 04:11 PM   #3
Sponsor: JET DV
The ram preview will use up to however much ram you have specified in the preferences. Can you change it to a higher number in the preferences? If yes, raise it an you'll get a longer section rendered. I'd probably lower it back down before the final render, though.
Old May 30th, 2008, 04:16 PM   #4
Yes Shift-B is what I do (Dynamic RAM Preview).
I though the preview mode would be individual, depending how much RAM the user got...
Ok, anyway now I know it is limited... thnx for responding...
Wait.. sry forgot to mention, a couple of years ago, I had Vegas 6 or 7, I dont remember, then I was able to use more then 1,2 or 3 seconds of preview in settings 'preview-Full'. I cant even remember that it was limited at all, because I hadent any problems at all with the shift-B...
I used 6-7 sec without any problems...
Old May 30th, 2008, 05:22 PM   #5
Sponsor: JET DV
Kim, have you gone to the preferences and changed the amount of ram to be used by the RAM preview? If not, give that a shot - you may be able to go higher - possibly MUCH higher - allowing a longer preview time.
Old May 30th, 2008, 05:37 PM   #6
ops... You where right, It was a couple of month ago I worked with Vegas, and I had totally forgot to change the amount of ram to a higher value then my 128 it was set too... =) thnx
Maximum choice is 1024, that would do about 8 sec or so, thats enough.. =)
