Colour Correction Summary at DVinfo.net
Old September 5th, 2008, 07:41 AM   #1
Hi,
I hope some of you might find the attached aide-memoire about colour and colour correction of use. I hope it's reasonably complete and correct but please feel free to make any input you might think useful.
The document is a Word document broken into Tables and is designed to fit on to two sided of A4 paper (which I've laminated and keep by my side when I'm working with Vegas)
Best Wishes,
Richard Jones
Richard Jones is offline   Reply With Quote
Old September 5th, 2008, 07:45 AM   #2
Thank you for your work, Richard.
Best
Ron
Ron German is offline   Reply With Quote
Old September 5th, 2008, 08:27 AM   #3
Great stuff. Did you create document?
Old September 5th, 2008, 11:48 PM   #4
Old Boot
My earliest of comments are:
A] Well Done!
B] I feel that your comment at the end, on the Brightness and Contrast Fx, should appear at the beginning!
C] Unless I missed it, you carefully explain Previewing but it would appear you omit the valuable Clipboard comparison option. Why?
D] Your Measuring tools are carefully delineated vertically. But should the horizontal delineations have any relationship to each other? It is kind of implied/indicated, as they are gridded horizontally, and you have delineated the tools vertically, which I found counter-informative. How about if you removed the continuous horizontal grid lines? Unless I have got this totally wrong.
E] I like your explanation of the "COLOUR CORRECTION TECHNIQUES". Are you also indicating a critical-path workflow by doing/indicating it this way? Meaning: Do Step 1:Exposure > Do Step 2:Set White Balance then . . . . ?
How about including a colour sample to indicate the issue?
Very well done. It will influence many a starter and this memory-challenged individual too!
Best regards
Grazie
Old September 6th, 2008, 04:37 AM   #5
Thanks for your supportive comments - they are much appreciated and any further advice will be welcomed.
Yes, Brian, it was my own work although compiled after a fair bit of research before being condensed into these Tables. When I came to look at colour I found the subject so vast and the instructions/guidance available so complex that I had to reduce it to this sort of analysis to keep myself on track without wasting too much time.
Grazie, many thanks for your considered and, as always, helpful comments. Looking at them:-
B. Good point and well taken.
C. Space was a problem. I wanted to keep it within two pages of A4 but will see if this can be done (in truth, I had thought I'd included it but I suppose we're all entitled to a senior moment now and again!)
D. No, you are right and this worried me as well. I'll give it some more thought.
E. No. I had originally given sequential numbers to the techniques but decided that this was suggesting a Work Flow which will not always be appropriate or suit everyone's way of working (although Expoasure and White balance are arghuably the best starting pointss before moving on to apply other techniques).
I should have loved to include a colour sample(s) but space was the problem as I wanted this to be a memory aid rather than a complete guide to colour. My hope that if anyone wants to explore an aspect any further this will help guide them to the appropriate instructions in the manuals, text books etc.
Best Wishes,
Richard
Old September 6th, 2008, 05:45 AM   #6
Thanks, this is very welcome information.
Paul Cascio
www.pictureframingschool.com
Paul Cascio is offline   Reply With Quote
Old September 9th, 2008, 08:00 AM   #7
Just to round this off, I've adjusted the chart to reflect most of the suggestions and now attach this in case it is of interest.
Regards,
Richard
Old September 9th, 2008, 08:24 AM   #8
nice! always like looking at snapshot summaries of all things nle... thx for posting!
-rob
Rob Wood is offline   Reply With Quote
Old September 9th, 2008, 10:30 AM   #9
Enormously appreciated Richard. Many thanks. I feel I should buy you a pint as you're just up the road!
Ian Stark is offline   Reply With Quote
Old September 9th, 2008, 01:08 PM   #10
Thank you!
Thank you So Much, Just what I needed as a beginner :).
Cheers.
Karim Amanali is offline   Reply With Quote
Old September 9th, 2008, 01:14 PM   #11
Beginner?!? I've worked with Vegas for 6+ years and it's just what I needed as well!!
Old September 9th, 2008, 02:22 PM   #12
Thanks! great stuff --
James Binder is offline   Reply With Quote
Old September 9th, 2008, 04:12 PM   #13
Dude, this is awesome!
May your camel have many offspring! :-)
thx
marks
Mark Stavar is offline   Reply
