Youtube Render With PAL DV at DVinfo.net
Old December 12th, 2008, 11:49 AM   #1
Hi Everybody,
With the new HQ mode on Youtube and 16:9 window i dont get my vids good now
on Youtube. Well not with my DV Pal 720x576 resolution vids anyway...
When i render a project with pictures and only motion effects it look very good with these
"Project Settings" and "Template" render settings:
---Project settings:
-Video
Template: Custom: 480x360)
Field order: None (progressive scan)
Pixel aspect ratio: 1,000 (Square)
Frame rate: 30,000 (30 FPS, not 30 000)
Pixel format: 32-bit floating point
Compositing gama: 2,222 (Video)
Full-resolution rendering quality: Best
Motion blur type: Gaussian (asymmetric)
Deinterlace method: Blend fields
-Audio
Master bus mode: Stereo
Sample rate (HZ): 48 000
Bit depth: 24
Resample and stretch quality: Best
---Rendering settings:
-Project
Video rendering quality: Best
-Audio
Mode: Quality VBR
Format: Windows Media Audio 9.2 Lossless
Attributes: VBR Quality 100, 96 kHz, 2 channel 24 bit VBR
-Video
Mode: CBR (Two-pass)
Format: Windows Media Video 9
Image size: Custom
Width: 1024
Hight: 768
Pixel aspects ratio: 1,000 (Square)
Frame rate (fps): 30,000
Video smoothness: 100 (Sharpest)
-Bit Rate
Internet/LAN: 8 M
***Note: when i do NOT change the "project settings" it looks very blockery to
on youtube, and what i notice in vegas that every motion effect which is
in QT format vegas see it as Photo in the vid Properties...strange.
But here is my problem....
When i want to render a vid (to nomather which format/resolution/project settings/template)
FROM a DV Pal 720x576(originel resolution) resolution project it looks so bad and blocky on youtube...
I tryd google, forums, etc to see what is the solution,but i havent, yet...
Greets
Elvis Poldervaart is offline   Reply With Quote
Old December 13th, 2008, 12:30 AM   #2
A-I would stick with mp4 source to YouTube if you can, it manages motion better with saturation.
B-what does the source look like prior to uploading?
C-why are you uploading 30p from 25p/50i source?
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old December 13th, 2008, 03:01 PM   #3
Dv pal
A: motion is not the problem as said in thread, it was an example but thx for the tip and will try that out to:)
B: its not fine ahum, it have stripes on vid, think it is the "square" 1.0000 render thingie?!
C: uuuuh that is a good one yes...lol
So can i leave project properties in original state (pal DV 720x576) ?
and render as template what i said before? only change frame rate?
thx
Old December 13th, 2008, 03:12 PM   #4
Dv pal
notice that render goes faster with 25 frame rate i believe...duh lol
hum this is pretty bizar, its not the "sqaure 1.000 thingie" when i render in 30 framerate (yes from a 25 pal dv source)
my vids dont have strips in it when i choose 25 frame rate i have stripes in it...
me..confused:S
***fixed*** it was the "blend" mode for deinterlace...
