Another Bug - Ignore event grouping at DVinfo.net
Old December 14th, 2008, 05:57 AM   #1
I have an event, "Ignore event grouping" was turned on, (accidentally), I then cut a section ( two places) & removed it & then realised on dragging the far one back that it was not grouped with the audio. However, it made no difference when I turned I.E.G. off or on, they just would not group. - Is this a bug or not ?
RonC.
Ron Cooper is offline   Reply With Quote
Old December 14th, 2008, 06:07 AM   #2
no. first get the A&V sync'd. Easiest way is right click on Audio, then goto MOVE (by slipping)-once sync's highlight both and press G to group the 2. Now when you have Ignore Event Grouping turned OFF you should be fine.
To me what is a "bug" and always has been since version 2 is being able to determine that IEG and some others is ON or OFF. The icons don't really tell the story.
Maybe it just my old eyes.
Don
Old December 14th, 2008, 07:12 AM   #3
Sponsor: JET DV
When you split them separately with Ignore Event Grouping turned on, you killed THEIR initial grouping as well. Bug? probably not. Unintended result? definitely.
Old December 14th, 2008, 02:29 PM   #4
Thanks Don & Edward.
I thought it might be something like that, but I am still surprised that it would act this way as the original event was virtually from the camera & perfectly synced.
Surely I.E.G. is either ON or OFF, regardless of what happened before, - and yes Don, there could be a more obvious indicator when these switches are applied. Wih my elderly eyes I realise that all these things are designed by young people with excellent vision.
RonC.
Old December 15th, 2008, 12:34 AM   #5
Old Boot
Well, Ron, how would it be for those of us that do not want the Grouping to remain AFTER a split? Can you imagine that? Here I go and repeat your process, with all the intention of killing the grouping relationship ONLY to find that at some point the Grouping was STILL in effect? Now how would THAT be? Can you imagine the mess I could get into?
Grazie
Old December 15th, 2008, 03:38 AM   #6
Yes Graham, I can imagine, as it is like my previous post, you would expect the thing to do as you selected, - ON or OFF, regardless of what went on before, - not stubbornly have a mind of its own.
RonC.
