Audio not importing at DVinfo.net
Old April 8th, 2009, 08:19 AM   #1
Audio not importing
I am trying to import a file that was rendered in vegas 7 from another computer to my laptop. The video imports fine, but the audio does not show up. It plays fine in wmp and all the other apps I have that will play video. Any help is appreciated.
tayproductions
Derek Grimes is offline   Reply With Quote
Old April 8th, 2009, 08:22 AM   #2
Sponsor: JET DV
What format is the audio? What type of file are you trying to import?
Old April 8th, 2009, 08:27 AM   #3
Importing a file
It is an mpg file. The audio is the default setting for the DVD NTSC template
tayproductions
Old April 8th, 2009, 08:31 AM   #4
Can you render it out as DV-AVI instead?
The audio will be there and the picture will be higher quality.
Old April 8th, 2009, 08:37 AM   #5
AVI File
Tried that. It does not work. The original file was an mpg file.
tayproductions
Old April 8th, 2009, 09:40 AM   #6
Then render the mpeg file out as DV-AVI and bring that into your laptop.
You're missing a codec on your laptop that you have on your desktop which is why the audio isn't coming in.
Old April 8th, 2009, 09:59 AM   #7
File
That was my first thought, but why would it play in WMP?
tayproductions
Old April 8th, 2009, 10:46 AM   #8
WMP can play all kinds of files (like DivX & XviD) that won't play properly in Vegas, even with the codecs installed on your computer.
Mike Kujbida is offline   Reply
