Video Wall - Page 2 at DVinfo.net
Old May 28th, 2009, 08:08 PM   #16
Ok thanks I found it. But for me it is different because I have Vista.
C:\Users\Harold\AppData\Roaming\Sony\Vegas Pro\8.0\Application Extensions
Harold
BhagaVideo.com
Harold Brown is offline   Reply With Quote
Old May 29th, 2009, 06:31 AM   #17
Sponsor: JET DV
Yes, you are correct. The actual path will vary depending on which OS you are using. Glad to see you found it. Bottom line is it needs to be located, the corresponding "9.0" folder needs to be made, and then it has to be copied to that new folder.
Edward Troxel is offline   Reply
