Vegas 5 allows saving up to 10 different screen layouts and easily recall them. ALT-D, 1 simply "recalls" the first layout. Glad that it worked to reset your screen.
Simple ?: Stopping cursor at end of clip
So i get to the end of my video clips and theres no more video frames yet the cursor keeps on going, having a good ole time. Is there a button or setting so vegas will stop the cursor at the last frame of video, without me having to highlight the clip?
THanks |
I just had to do something similar yesterday to solve a slight visual jitter problem occuring in just one section of a 90 minute project that was occuring whenever I used the MainConcept encoder, even at 2 pass encoding (it occured after fading in after a mid-title section).
So I frameserved to the TMPGEnc encoder (which is known to be slower then the MainConcept one) and that solved the jitter problem. The MainConcept encoder encoded at 1.33:1 and the TMPGEnc encoder encoded at 2:1 (both using 1 pass as it was a draft review copy). It was worth the extra time to get the problem fixed. |
Importing a veg file
How can I import one project into another project? I was looking to edit and save each of my scenes for my movie individually, so that I can assemble them together later. Can this be done? Thanks.
Open two instances of Vegas and copy from one, then paste into the other. You could also render each segment and assemble those in another project.
Gary |
Thanks, that worked like a charm.
In most cases, playback will stop a few seconds after the last clip on the timeline. However, I have seen cases where it just keeps on going. You can always just press the space bar or enter to stop the playback.
Nope, this one doesn't stop it just keeps on going like the energizer bunny. I guess i could "just" press the space bar but i'm trying to be really lazy/efficent and see if the cursor would stop automaticly so it doesn't keep moving the time line to a new screen
<<<-- Originally posted by Edward Troxel : In most cases, playback will stop a few seconds after the last clip on the timeline. However, I have seen cases where it just keeps on going. You can always just press the space bar or enter to stop the playback. -->>> |
Here's a hint: Start playback, click somewhere on the timeline or just slightly move the timeline. Now the timeline will continue to play but the screen will never be updated until you pause playback!
Thanks Glenn, very subtle work.
I liked the highlight across the drummer's shirt , creating contrast between the subject and background using cool vs warm, and enhancing the lighting. Excellent. Scott |
My video lags on the time line
When I play my clips in the Trimmer Bin, they play fine, but when I play SOME of my clips on the time line, they have this ghostly lagging effect to them. By the way, I shot in 24pA mode with the DVX100A. What could I be doing wrong here? Why are some clips playing smoothly, and som aren't?
Hmmm...now the problem is gone...but why could this be happening SOMETIMES?
Pip Bouncing Ball Transition
I've created a basketball video with stills that fly in and out as the video plays. My question. Is there an easy to use transition to make the still picture bounce in and bounce out. I have tried the "Wax Bouncing Ball" transition but having alot of problem getting it to work eg. crashes Vegas. Any other transitions out there where I can do this or is it easier to work within the track motion and manually produce this?
Thanks in advance. |
Latency of Creative's ASIO drivers
Why does my audio surge ahead noticably when using these drivers, compared with DirectShow? I thought the idea was to achieve zero latency.
It could be the preview quality. If it is set too high, the computer might not be able to keep up. I always edit in "Draft" mode.
| All times are GMT -6. The time now is 01:04 PM. |
