Work Flow Suggestion for Multi Cam Shoot Please at DVinfo.net
Old September 2nd, 2009, 05:43 AM   #1
I am looking for suggested workflow ideas for Multi Cam shoots.
Here is my current workflow:
Make Folder on Hard Drive and Name it
Create Subfolders and title them Each Cam 1, Cam 2,
Capture video to appropiate folders.
Drag each Camera to its own Video Track
Synch Videos
Enable Multi Camera Function
Make first Edit from Multi Track Video, ie cuts, blurs, etc
RENDER track as AVI file RENAME
Do final editing, ie final cuts, transistions, color corrections,blur out items, etc
Render for final output in desired format.
Is this correct or is ther an easier way?
Vegas 8.0c (Build 260)-(Upgraded to Sony Vegas 10 pro)Canon GL2, Canon HV30, HF200, HF20-Sony UWP Wirelesss Mic Kit, Intel Core 2 CPU-6600@2.40GHz-3.00GB Ram
David Ruhland is offline   Reply With Quote
Old September 2nd, 2009, 07:24 AM   #2
Sponsor: JET DV
I'm not sure why you need the intermediate render but, other than that, it sounds like you're on the correct path.
Old September 3rd, 2009, 09:00 PM   #3
Sounds pretty good.
You might consider, instead of rendering out to AVI and then doing final post on that, simply opening a new project and pulling the multi-cam .veg file in as a sub-project. This will still allow you to do the post work (CC, etc.) but it also allows you to easily tweak the original project if you need to with out the overhead of the full re-render.
I have used this approach successfully on a number of projects.
Just a thought.
mark
mark stavar
http://www.swandancer.com.au
Mark Stavar is offline   Reply
