Vegas Video discussions from 2006 (Q3Q4) - Page 77 at DVinfo.net
Old October 23rd, 2006, 12:16 AM   #1141
Originally Posted by Carl Downs
... a few of the scenes (consecutive of course) have a small blob in the picture... HOW do I fix it? Dont tell me I have to go frame by frame???...
Carl, you are going to know a whole lot more about track motion by the time you are done with this.
Grab some frames of video to make your stamps with. (if you need guidance on this, look at the second post in this thread http://www.dvinfo.net/conf/showthread.php?t=48730)
Take them into photoshop or paintshop pro or your favorite image editor and cut out everything but the stamp area. Export as a .png with transparency.
You could also do this within Vegas using cookie cutter on a still that you copy and paste if that's easier than photoshop - either would work fine, I find working with an external still image editor a little easier.
Create a new video track in Vegas, above your existing video track(s). Drop your png into the new track, over the relevant section of video.
The next steps are to open track motion for that track (the icon with two rectangles & an arrow in the track header), and then move the image around until it covers the blob. If the blob is stuck to the lens I guess you don't need to do any motion tracking.
If there are transparency issues, look for the "compositing mode" icon in the track header and make sure it's set to "source alpha".
If you do have to do some tracking, check out Edward Troxel's excellent Vegas Tips newsletters at www.jetdv.com
Take a look at Vol 1 #12 - November 2003
Blurring Faces a la “Cops”. The application is different, but the use of keyframes in track motion is the same.
Seth Bloombaum is offline
Old October 23rd, 2006, 12:39 AM   #1142
very basic question
I am attempting my first Vegas edit and have problem with audio. When I place my clips on the timeline there is an audible click between adjoining clips. I cannot find the way to join two clips seamlessly. I've tried to drag all the clips together from the media pool to the timline but than I get audio compression between each clip. I am stuck.
Andrew Jezierski is offline
Old October 23rd, 2006, 02:53 AM   #1143
I'm not sure exactly what the problem here is... can you give us more info?
The clicking part seems really strange. You're talking about two clips of audio that are touching each other, right? And the clips sound fine by themselves?
Can you explain what you mean by getting "audio compression between each clip"?
-->jarrod whaley.
www.oakstreetfilms.com
Jarrod Whaley is offline
Old October 23rd, 2006, 06:19 AM   #1144
Peter,
Yes, I checked the footage on an normal TV, but that was the first time I noticed something was very wrong. On my computer, Windows Media Player shows regular interlaced footage very smoothly (just like a TV) and with no weird horizontal lines by the way. It just goes wrong with the by Vegas 7 anamorpically stretched interlaced footage..
Furthermore, those screengrabs are from Media Player and not from the (low quality) Vegas preview window. Also, Premiere Pro 2 isn't de-interlacing. It looks just as smooth and sharp as the original AVI (trust me on this, I know how to recognize de-interlaced footage)
Perhaps it's nog a bug, but it's just a feature Vegas doesn't have?
Bram Corstjens is offline
Old October 23rd, 2006, 08:54 AM   #1145
Have you tried using the primary color corrector that comes with Vegas? It's very powerful and that (plus the secondary color corrector) is what most people use for fixing white balance in Vegas. There's quite a lot of discussion about how to do it on the Sony forum.
If you are looking for a "one click" solution, I don't know that there is any solution (for any NLE) that can get consistently good results. But I know there is an "auto levels" plugin from Mike Crash that is free.
Jay Hancock is offline
Old October 23rd, 2006, 09:27 AM   #1146
Excalibur Sync Question
I have three camera feeds from a shoot this weekend. Due to an error on the beginning sync, I have to sync near the end of the feeds. That is the first problem. The second is that one of the cameras starts and stops halfway through, before the sync point.
I split that track and made the second half camera 4 and fround the sync point, calling it s4.
Is there any way to set up a second set of sync points for the first half of that track, I can sync it to one of the other tracks, just not both.
Make sense?
Kevin James is offline
Old October 23rd, 2006, 10:04 AM   #1147
Old Boot
Originally Posted by Dwight Flynn
Anyone know of a good set of plugins (economical or demo if possible) that will give me different options for white and warm balancing in Vegas?
Dwight
Before you go out on a limb, DO try Vegas' own Colour Curves "Warm Colours" profile - EXCELLENT! Or you could knock-up your own.
Graham Bernard is offline
Old October 23rd, 2006, 10:40 AM   #1148
Andrew, I'm in Windsor as well so I've sent you a private email.
Mike
Mike Kujbida is offline
Old October 23rd, 2006, 10:59 AM   #1149
Sponsor: JET DV
Go ahead and just sync that one clip manually. You can use the 1/3/4/6 keys on the numeric keypad to fine tune the placement left and right.
Edward Troxel is offline
Old October 23rd, 2006, 11:00 AM   #1150
Fred Retread
Zoom in and check for the presence of very short fade out and fade in at the intersection between two clips. That's one thing that causes a click. Vegas will insert such fades when you split a clip in Vegas if the prefs are set that way.
You didn't mention how the clips got created to begin with. But in the event that they are not clips that were split from a single track, then they simply may not match well enough. I've had success with cross-fading such clips by simply dragging the end of one over the beginning of the other slightly.
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline
Old October 23rd, 2006, 12:22 PM   #1151
Thanks Edward!
I hit create project after putting in my markers, and nothing happened.........?
Old October 23rd, 2006, 01:27 PM   #1152
Sponsor: JET DV
You hit "Sync" instead unless you're talking about the camera switches - in that case you use the Multi-Cam button.
Create Project is used if you have nothing on the timeline and want the clips you select to be automatically added and the tracks automatically named in preparation for the rest.
Old October 23rd, 2006, 02:14 PM   #1153
After closer scrutiny it looks like both audio and video are affected. I had 3 cameras rolling continuosly but my capture was set to scene detection so I ended up with lots of clips, even from stationary cameras. It seems that I cannot seamlessly connect those events (from one camera/one tape on a single track- I haven't attempted to sinchronize all three yet). With audio I get either a compression when it slightly overlaps or a "click" when there is a space between the events. Actually click perhaps is not an acurate description - it is an audio artifact similar to one when someone is plugging in audio cable or something like that. I tried different settings with "quantize to frames" and snapping tool off and on but to no avail. I've tried to manually connect the events on the timeline or drag a selection of clips from the media pool to the timeline hoping that Vegas would put them together seamlessly. Perhaps I expect to much from the program and need to recapture each tape as a single clip. Thanks for your help.
Mike - great to find a local expert!
Old October 23rd, 2006, 02:48 PM   #1154
While that would be the best bet, since there's no way to join video files together without editing them together and rendering them, I still don't understand why an empty area of audio track between clips would give you anything audible at all. And I still don't know what you mean by "compression" when audio events overlap. Do you mean there's a crossfade or fade ins/outs at the edges of events? If that's the case, you can turn off these auto fades in the preferences somewhere (or at least adjust the length of the fades down to zero).
-->jarrod whaley.
Old October 24th, 2006, 06:31 AM   #1155
Thank you Seth
I will give your advice a try... hopefully it is not too time consuming...
Carl Downs is offline
