Out of sync problem????? HELP at DVinfo.net
Old March 25th, 2005, 05:51 PM   #1
Using Vegas5....
I drop a m2t file onto the timeline then render out to mpeg2 and burn to dvd...
Somewhere along the way... the video and audio get out of sync horribly bad...
HELP!
B
Brent Marks is offline   Reply With Quote
Old March 26th, 2005, 04:53 AM   #2
I am getting similiar problems. I recorded some footage with my 9600 AIW card. I have 5 video files, about 15 min each. They are .mpg. I dropped them into Vegas, edited out the commercials, strung them together. They look fine in the timeline. When I export them as Video for Windows DV NTSC, the audio is way way off.
Right now, I'm exporting them seperate. I'm going to try putting them togther in virtual dub and hope that works. Hopefully it's not exporting them at different speeds (ie: speeding up the footage even the smallest amount in the export). Though... it doens't get progressively worse in the file. It's only after the first edit point. So the first 15 min are fine. Then its all way way off.
Bryan Mitchell is offline   Reply With Quote
Old March 26th, 2005, 07:18 AM   #3
Comon guys...?
Anyone...??? We need help here...
This has to be a common simple problem?
How can we fix it
Old March 26th, 2005, 08:34 AM   #4
Sponsor: JET DV
Bryan's problem I can understand. Capturing via an AIW into an MPG is not a good option. Much better to use an external convertor and capture to DV-AVI. Then all his problems would go away.
Brent's problem - could you explain a little more? Are you doing hdv?
Old March 26th, 2005, 10:02 AM   #5
Shooting on HDR-FX1...
capturing HDV using Cineform Connect HD
capturing to m2t file...
Dropping the m2t file onto Vegas timeline
then doing a simple render out to mpeg2
HELP!
Old March 26th, 2005, 04:09 PM   #6
Have you tried converting the audio to the project settings then putting it on the timeline ,syncing it with the existing audio, turn off the events audio ,then render?
Jack Smith is offline   Reply With Quote
Old March 26th, 2005, 04:42 PM   #7
no, i have no clue as to what u just said...
why would i need to do all that?
can't vegas handle it?
Old March 26th, 2005, 05:38 PM   #8
See the thing is.... After several tests.... It's the Video that is off. Not the audio. I exported each seperatly, then played them back. The audio played back beautifully, with no sign of the cuts. The video however, had parts of the commercials I had cut out, along with alot of other really weird side effects. For some reason, even though I cut it, and even though it looks fine in the timeline, IT's exporting the video differently than I have cut it. It's 45 min long... And only 1 vid track, 1 audio track. This is absolutely ridiculous....
Old March 26th, 2005, 06:31 PM   #9
Anyone...?
HELP
Old March 28th, 2005, 12:17 AM   #10
bryan, it sounds like vegas isn't combining the mpegs correctly... download the womble demo and see if it'll put 'em together and keep 'em in sync... but ed is right, you shouldn't even be using mpeg as a capture format... unless it's hi-def off of a cable feed?
Dan Euritt is offline   Reply With Quote
Old March 28th, 2005, 06:19 AM   #11
Fred Retread
Brent,
I guess the problem is that not many people are working with HD (including me).
If you have confirmed that the audio is in synch on the timeline, try rendering the project to .avi first. You're demanding less of the program when you do that. Once you have it in .avi rendering to .mpg should be smooth.
Another option along the lines of Jack's suggestion above is to try rendering the audio alone into a .wav file. Then add that wave file to a new track in your project. Make sure it's in synch, mute or delete the other sound track and render.
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline   Reply With Quote
Old March 28th, 2005, 08:49 AM   #12
My final product doesn't have to be HD....
I just want to maintain the quality and the 16x9 aspect ratio.
What's the best way for me to capture/edit?
Old March 28th, 2005, 09:39 AM   #13
Sponsor: JET DV
http://vasst.com/hdv/hdv-FAQ.htm
http://www.manifest-tech.com/media_pc/hdv_jvc.htm
http://www.sundancemediagroup.com/ar...frameserve.htm
Old March 28th, 2005, 11:13 AM   #14
How are you guys editing then???
What am I missing here?
Old March 28th, 2005, 08:49 PM   #15
Most of us are capturing DV-AVI and editing in that format. Then you render to whatever you want.
Steve
pdx10, EOS10D
Steve Roffler is offline   Reply
