The Vegas Blur - Page 2 at DVinfo.net
Old May 30th, 2005, 07:39 AM   #16
Originally Posted by Edward Troxel
No, Patrick, you're not wacked. That button should have absolutely no effect unless Motion Blur has actually been applied to the project. A Motion Blur envelope is added on the Video Bus Track.
Yes, that's what I thought. But I discovered that anytime I made any change to an event -- even a simple pan/crop to letterbox the event -- the result would be an immediate and markedly noticeable degradation of the footage.
Clicking the motion blur bypass tab immediately corrected the problem. It was like going from a second or third generation xerox copy to a crisp original, instantly.
If anyone else can explain why this happened, I'd be curious to know.
Rob Gregory-Browne is offline   Reply With Quote
Old May 31st, 2005, 12:29 AM   #17
Rob - have you double checked that no Motion Blur was applied?
(Ctrl-Shift-B to display Video Bus Track - right click to show envelopes)
If not, this is a mystery, as if there is no Motion Blur, there should be nothing to by-pass ......
Peter Wright is offline   Reply With Quote
Old May 31st, 2005, 07:18 AM   #18
No motion blur has been applied, so I can't explain why hitting bypass makes a difference, but it certainly does -- and not even a slight one.
Thinking it might have something to do with my setup, I downloaded a copy of the Vegas 6 trial at my office and discovered the same problem there as well.
Whatever the reason, at least there's a solution.
Old May 31st, 2005, 04:11 PM   #19
I found in my Vegas 6 trial a bug in VideoFX - if I want to use SHARPEN, its presets are exactly like QUICK BLUR !?!?!?!?!?!
Plamen Petrov is offline   Reply With Quote
Old May 31st, 2005, 04:21 PM   #20
Its a conspiracy.We all need to get out of town...NOW
Don Meers is offline   Reply With Quote
Old May 31st, 2005, 04:51 PM   #21
Another interesting thing I'm finding is that if I click "use Microsoft DV Codec" in my preferences, the problem doesn't seem to happen. Could it be the Sony codec? I always thought it was supposed to be superior to the MS codec.
Old May 31st, 2005, 09:25 PM   #22
Sponsor: JET DV
Update to 6.0b and the blur effect will blur once again.
Old June 2nd, 2005, 01:12 PM   #23
I believe the MS codec being referred to is a DV-AVI codec (hence the "DV" in the name). This should have no effect if you're rendering MPEG-2.
Good luck.
Dennis
Dennis Vogel is offline   Reply
