Viewing individual frames on the Video Track at DVinfo.net
Old May 30th, 2005, 08:30 AM   #1
How do I have my video track setup so that I can see each individual frame from my video on it? Thanks.
Glenn Gipson is offline   Reply With Quote
Old May 30th, 2005, 09:32 AM   #2
You can keep hitting the little "plus" sign at the bottom right of the video window until you reach individual frames. I usually just keep hitting the "up" arrow key. It does the same thing.
Probably also a shortcut but I will have to defer to the Vegas experts out there.
Steve
pdx10, EOS10D
Steve Roffler is offline   Reply With Quote
Old May 30th, 2005, 09:35 AM   #3
Well, what I am asking is how do you VIEW individual frames up on the ACTUAL time line itself, instead of frames that are simply spaced out on the time line.
Old May 30th, 2005, 11:01 AM   #4
Hi Glenn,
Based on what you originally asked, I would've assumed Steve answered your question, but apparently not. I've tried over and over to parse your "clarification", but it's just not making sense to me. Wanna take another shot at it?
-cw-
Charlie Wilkinson
Full-time SysAdmin/Programmer
Part-time Videographer wanna-be
Charlie Wilkinson is offline   Reply With Quote
Old May 30th, 2005, 02:25 PM   #5
Glenn,
I'll take a stab at it. Right-click the timeline and select a rate in SMPTE frames to match your video (drop, non-drop, 24p, whatever it is). The timeline numbers are now in hours:minutes:seconds:frames.
Select a point in the video event on the timeline and roll the wheel on your mouse forward (or press the up-arrow key) until the last digit above each frame is successive (xx:xx:xx:14, xx:xx:xx:15, xx:xx:xx:16). You are now looking at individual frames and each press of the left-arrow or right-arrow key will move one frame in the corresponding direction.
This would probably be a good thing for someone to write a script to speed the selection of this view.
Fear No Weevil!
Patrick King is offline   Reply With Quote
Old May 30th, 2005, 05:18 PM   #6
>>Wanna take another shot at it?<<
Hmmm. Ok, let me explain it like this. There is an option to NOT have Vegas show each individual frame on the actual TIME LINE. When I first got Vegas, I turned this off. This allows for the program to quickly render out the video time line, therefore speeding things up. My video time line looks something like this:
[frame]---white spacing---[frame]---white spacing---[frame]
What I want to do is have my video time line look like this:
[frame][frame][frame][frame][frame][frame][frame][frame]
No matter how close I zoom in, the white spacing between frames ALWAYS shows up on the video time line. This is the best way I can explain it.
Old May 30th, 2005, 05:20 PM   #7
Patrick, I'll take a stab at your directions after my Vegas computer is done rendering. Thanks.
Old May 30th, 2005, 07:25 PM   #8
Glenn,
If you see this...
...you are zoomed in too close, zoom out using the technique I described. Zoom out one mouse wheel click at a time until you see...
..with a unique timecode above each frame (e.g. xx:xx:xx:14, xx:xx:xx:15, xx:xx:xx:16).
Fear No Weevil!
Old May 30th, 2005, 08:08 PM   #9
Sponsor: JET DV
You might try changing the HEIGHT of your video track. Or you can totally turn off the thumbnails in preferences (of course you turn off the wave-forms too).
Old May 30th, 2005, 08:41 PM   #10
And thats really something I thought would change with V6. How long will Sony continue to take a beating over this issue.
Fear No Weevil!
