Options for slowing 30p at DVinfo.net
Old February 8th, 2010, 07:36 AM   #1
I need some clips to slow down by 50%.
What switches do I have to check ?
If I check disable resample , does Vegas duplicates each frame ?
If checking force/smart resample , does vegas create and adds an interpolated frame ?
What option is considered better ? Will AE give better results ?
sassi
Sassi Haham is offline   Reply With Quote
Old February 8th, 2010, 01:42 PM   #2
Here is a short 720p 60fps clip shot with a 7D:
Index of /yoyodyne/slow mo clip
I've been having good luck slowing down clips in Vegas thusly:
- 24p project
- drop 60p clip on timeline
- right click video clip - properties - change playback rate from 1.000 to 0.400
probably have to ram preview to playback the raw 7D file, render to Cineform/etc. for better preview. Should look pretty smooth.
Hope this helps.
Burk Webb is offline   Reply With Quote
Old February 9th, 2010, 10:10 AM   #3
- 24p project
Hope this helps.
I think you missed his point. He's got 30p footage he wants to slow down.
I think you've basically got it right. Resampling will blend frames, no resampling will double them up. If you want better interpolation, you need to use outside tools.
BayTaper.com | One man's multimedia journey through the San Francisco live jazz and creative music scene.
Bill Binder is offline   Reply With Quote
Old February 9th, 2010, 11:39 AM   #4
Doh.
It was the "I need some clips" comment that got me...
Bill sounds right on with his advice.
Old February 9th, 2010, 10:31 PM   #5
Bill, If I get you right, outside tools will interpolate better ?
Old February 13th, 2010, 01:41 PM   #6
Dont forget to set ruler to Absolute frames.
If your settings are right Vegas can do a VERY good job of this.
Gerald Webb is offline   Reply
