Vegas Video discussions from 2006 (Q1Q2) - Page 127 at DVinfo.net
Old June 13th, 2006, 02:40 PM   #1891
VST Plugins
Hey all,
Vegas 5 user here - have been playing around with the Vegas 6 demo.
I use a handful of audio plugins and virtual instruments to record with in Vegas. In Vegas 5 some of these work, some don't and a few I have to run cables out unused outputs of my A/D box and back into my mixer to be able to record with them.
In the Vegas 6 demo I find I've been able to open all my virtual instruments and audio plugins except M-Audio virtual keyboard programs. Does anyone know if it's possible to use M-Audio KeyRig or the M-Tron as a VST plugins in the audio chain of Vegas 6? According to the documentation they will both work this way with most standard DAWs but it doesn't actually mention Vegas.
thanks,
Dan B
Dan Barnhill is offline
Old June 13th, 2006, 05:07 PM   #1892
Hawaiian Shirt Mogul
there are many different kinds of MFX files ..from what camera ? or what capture system ?
Don Donatello is offline
Old June 13th, 2006, 05:08 PM   #1893
Images: 1
Originally Posted by Phillip Jackson
grrrr... Sorry was supposed to be in Vegas section... can someone move it? i need sleep.....
No problem..headed for the Vegas forum.
-gb-
Greg Boston is offline
Old June 14th, 2006, 01:50 AM   #1894
High contrast cause interlace problems?
Still editing my first wedding video!!!!
EDITED - I've now managed to upload the clip in question - it's here
I'm creating the highlight piece to Van Morrison's Moondance. You'll see 6 clips appearing in rapid succession. On the computer screen it looks great but when I play back on TV the first set of rectangles play OK but as they are replaced by the second set the screen becomes unstable with the rectangles jitterimng vertically - completely spoils the effect. The clip was created using event pan/crop to adjust the picture width, event fx to add the border and track motion to place the picture.
I've tried reducing the size of the rectangles so they're further into the screen but this doesn't help. The only way I can get it to remain steady is to change the rectangle border from white to grey or to change the background from black to a dark grey.
Is this problem caused by the black and white contrast, the speed of change or is there something else I'm missing. I've tried 'reduce flicker', 'force resample' and render at best quality. I use the DVD Architect template and then use DVDA to make the DVD. This is PAL by the way.
Thanx
Ian
Ian Briscoe is offline
Old June 14th, 2006, 06:21 AM   #1895
I'm not totally sure what kind they are, i've only downloaded 2 different ones.
Its just we supposedly gonna be shooting on XDCam and as it says in the Vegas Help that it can use the .MXF files straight from the disc i thought it would be best to grab them rather than having it transfered to miniDV.
Can anyone point me to more information on .MXF files and what kind Vegas will like?
Anyone used .MXF files in Vegas? can you email or send me link to download one to try.
Phillip Jackson is offline
Old June 14th, 2006, 06:23 AM   #1896
Oh , guess i should mention that no i haven;t got access to the XDCam to try the files from there, i'm not sure its even happening yet.
so thats why i downloading whatever .MXF files i can find to try it out first.. so when or if it comes i'll have things sorted..... hopefully :)
Old June 14th, 2006, 08:19 AM   #1897
Without seeing exactly what you're talking about, I'd say that this is probably just one of those things that interlaced video can't handle very well. You may just have to try that grey border.
One more thing you might try is a small amount of gaussian blur; you might try as much as 0.003 on both settings (though go with 0.001 or 0.002 if you can). That will make for a less abrupt transition between white and black.
-->jarrod whaley.
www.oakstreetfilms.com
Jarrod Whaley is offline
Old June 14th, 2006, 08:36 AM   #1898
Phillip,
there are .mxf files from both XDCAM and from Panasonic (and Grass Valley) on the VASST site. Free downloads. Other sites have at least HVX footage to download for experimenting.
XDCAM will load straight to the Vegas timeline. Panasonic's flavor requires conversion using either CineForm or Raylight.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline
Old June 14th, 2006, 10:24 AM   #1899
Jarrod
Thanx for the tip - I'll try that - note I have now editied my original post and managed to upload the clip.
Ian
Old June 14th, 2006, 11:08 AM   #1900
Ian,
It's more likely that your black and white values are out of legal bounds. Is there a Broadcast Safe filter you can use?
Josh
Owner/Operator, 727 Records
Co-Founder, Matter of Chance Productions
Blogger, Try Avoidance
Joshua Provost is offline
Old June 14th, 2006, 11:14 AM   #1901
Sponsor: JET DV
Yes, Vegas has a Broadcast Safe filter. It may be just as easy to simply make sure the colors fall within the 16-235 range instead. (i.e. instead of 255,255,255 use 235,235,235 which will still look white but won't be "pure" white which can cause problems)
Edward Troxel is offline
Old June 14th, 2006, 12:06 PM   #1902
You can also put a 16 16 16 RGB black background underneath... the Vegas default is 0 0 0 RGB, which is not a legal black.
Glenn Chan is offline
Old June 14th, 2006, 12:33 PM   #1903
Sponsor: VASST
I don’t have M-Audio KeyRig but I do have M-Tron and it does not plug in. I’m not sure it really is an audio plug-in. What would it process? (it’s just a sample player) I have use Native Instruments B4 in Vegas as a Leslie effect and it works great.
~jr
Developer: VASST Ultimate S, Scattershot 3D, Mayhem, FASST Apps, and other VASST Software plug-ins
Web Site: www.johnrofrano.com
John Rofrano is offline
Old June 14th, 2006, 01:14 PM   #1904
Lost Keyframe
One of my favorite tools is keyframing special effects...for example making the lens flare effect move across a picture/video clip.
Unfortunately, the keyframe feature is gone from all video effects work areas.
I can still keyframe in Pan/Scan, but in nothing else. I suspect I accidentally removed it somehow, I have a vague memory of having had no sleep for three days and messing something up a while ago, but I'm not sure what is going on!
Appreciate any help...
Jeff Harper
Cincinnati, OH
Jeff Harper is offline
Old June 14th, 2006, 01:31 PM   #1905
Sponsor: JET DV
Open up the window missing the timeline at the bottom of the effect screen. Move the mouse SLOWLY to the bottom of the screen. As soon as it turns into an up/down arrow, click and drag upwards.
The timeline at the bottom of the effects windows is resizable. You've apparently resized yours to nothing.
